Why I get during start MC 3.0 (just upgraded from 2.8) this message:
LogFile_ForMC::LogFile_ForMC()Error [-16777178] unable to:newLogFile -> OpenFile() failed
I cannot go throu this message. i don´t know what is wrong.
Thanks a lot for help.
Jiri
When you installed, did you uninstall the previous version and follow all of the instructions for cleaning out your registration as stated in the Read Me document?
Also, what is your system configuration? (OS, system model, Avid HW, graphics card, storage, etc.)
Yes, I have all uninstalled as is described in instruction. I try it twice with the same result. If I try start Avid MC 3.0, window with uploading information is shown, ending at Configuring Digital I/O Subsystem. After this error message appears.
Previous version MC 2.8.1 was ok.
I have Win XP Pro SP2, no Avid HW (software only), graphic card NVIDIA FX560.
I tracked down the error in the source code. They app is trying to create a log file in the "Reports" folder. The log file lives in the My Documents folder. For example:
C:\Documents and Settings gonsalv\My Documents\Reports\AVID_VDM_log__00.txt
Are you logged in with Administrator privileges?
- Rob
Yes, I am logged with administrator privilegies. what can I do?
In Eventlog.log is:
20080612212525 Startup DeMille_A_Release_R56850 (XP Media Composer 3.0)20080612212528 Shutdown Application is terminating normally
In Appevent.log is:
1. Download DebugView and UnZip
http://technet.microsoft.com/en-us/sysinternals/bb896647.aspx
2. Run DebugView
3. Run MC 3.0 until you see the error
4. Post the last 10 lines
There are:
00000055 2.88365626 [1308] DIOWinDeviceLoader[8]: DIOloader - Loading DIOPyromaniacOHCI.dll 00000056 2.88573456 [1308] DIOPyromaniacOHCI DLL Loaded 00000057 2.88576818 [1308] DIOWinDeviceLoader[9]: DIOloader - Checking version number 00000058 2.90389299 [1308] MSDVStream::BuildGraph - Cannot create video capture filter 00000059 3.91233397 [1308] MSDVStream::BuildGraph - Cannot create video capture filter 00000060 4.93023062 [1308] DIOWinDeviceLoader[10]: DIOloader - Retrieving base object 00000061 4.93030119 [1308] DIOWinDeviceLoader[11]: DIOloader - disabling thread calls to DLL 00000062 4.93032837 [1308] DIOWinDeviceLoader[12]: DIOloader - completed 00000063 4.93035746 [1308] DIOWinDeviceLoader[13]: 1 device types loaded 00000064 4.94104671 [1308] 00000065 4.94104671 [1308] FileWriterForWin32::OpenFile( 00000066 4.94107103 [1308] C:\Documents and Settings\All Users\Data aplikací\Avid Media Composer\Reports\AVID_VDM_log__00.txt 00000067 4.94109535 [1308] ) - failed : 00000068 4.94109535 [1308] OSmsg>> 00000069 4.94111872 [1308] Systém nemůže nalézt uvedenou cestu. 00000070 4.94114304 [1308] 00000071 6.07496023 [1308] DIOPyromaniacOHCI DLL Process detach 00000072 7.22582769 [1308] 5209.353065 LogFile_ForMC::LogFile_ForMC() Error [-16777178] unable to: newLogFile->OpenFile() failed.
1. Browse to C:\Documents and Settings\All Users\Data aplikací\Avid Media Composer\
2. Click on the Reports folder and bring up Properties, Advanced
Do you have permission to read / write / create files?
3. Step into the Reports folder
Can you create a new text file in the folder?
Thank you, by Debbuger I found, that Reports folder was mising. I created it and MC launched.
Now I have another problem occured - when I try open each project created in MC 2.8 (MXF) there is message: Unsupported resolution. Why?
Is the message in a dialog box or in the record monitor?
What is the exact text of the error message?
What is the format of the project? (i.e. PAL 25i)
What resolution(s) are you using? (i.e. 2:1, DV25 420, etc.)
Message is in dialog box:
Exception:Unsupported resolution
Format and resolution of all projects is 25i DV 25 420
It sounds like an installation problem.
1. Go to Control Panels->Add Remove Programs and uninstall Media Composer, FilmScribe, EDL Manager, MediaLog, and Avid Log Exchange.
2. Using RegEdit, Remove the following Registry keys on your system if they still exist after the uninstallation process.
HKLM/Software/Avid Technology/<productname>
HKLM/Software/Avid Technology/AVX Plug-ins
3. From the following folders, remove any folders that do not have custom data in them that you want to keep. If you do have custom data, copy the data to the new locations after step 4.
C:/Documents and Settings/AllUsers/ApplicationData/Avid/<productname>
C:/Program Files/Avid/<ProductName>
(Vista) C:/ProgramData/Avid/<Productname>
4. Install the new Avid editing application.
I did everything and reinstalled MC 3.0, but two problems (missing Reports folder and Message:Unsupported resolution) are same. I repeated creating Reports folder, but second problem I can not solve.
After clicking OK in error dialog box I can play source material, but if I am trying play sequences (with filler allready inserted) or load filler error dialog bog (Message: Unsupported resoluiton) appear.
I think that problem can be in filler, but I don´t how can I solve it.
