Hi, there.
Does anyone know if this is possible?
Because I don't own Protools yet, I'd like to edit in Medai Composer and sweeten my audio in Adobe Audition. Theoretically, this is supposed to work, but I can't get it to. Avid no longer seems to allow straight OMF export (the way FCP 7 does and the way Avid apparently used to) Instead, you export an AAF with OMF media attached? (or something like that - I don't understand this concept) However, Audition doesn't import AAFs (but it does import straight OMFs beautifully). I imagine that this clash is an Avid Vs. Adobe issue. One workaround idea I came up with was to import the Avid AAF into Premiere and try to export from there, but the AAF import into Premiere is crashing Premiere. I've read posts online about Adobe saying it's possible to import AAFs from Avid, but that in reality it never really works. The last resort I have is to export each of my Avid audio tracks as individual .wav files. A lot of work and not very flexible, but that's the best I could come up with. Does anyone have any experience going from Avid to Audition?
S.Clements: The last resort I have is to export each of my Avid audio tracks as individual .wav files. A lot of work and not very flexible,
I´m doing that all the time when I´m using Audition, add MI - MO to a copied sequense, export wav between in and out 10 secs or so, throw that wav into Audition, same 10 secs, do my stuff and save as new, maybe a little more than 10 secs depending on what I have done, importing back into Avid, same 10 secs and as MI and MO already are marked just to replace with that new clip.
Maybe a couple of minutes / clip .
Tomas
Thanks for confirming your workflow, Mjoinarn. I guess my thinking was that this isn't as flexible as an OMF export, because you're exporting entire tracks (say for a 2 hour feature, for example) It seems a bit "old school" to me. Also, I'm not familiar with the term MI-MO. What does that mean? Thanks for the input.
You´re welcome and MI MO is just Mark In and Mark Out
hth
You should be able to generate an OMF from MC by first going into the Audio Project Settings window and changing the audio file format from PCM (MXF) to Wave (OMF). I didn't try this for a while but it used to work on V5.5.
David Richardson: You should be able to generate an OMF from MC by first going into the Audio Project Settings window and changing the audio file format from PCM (MXF) to Wave (OMF). I didn't try this for a while but it used to work on V5.5.
Thanks, David. I had tried switching to an SD project in Avid to force an OMF export (with poor results), but didn't try the route you suggested. Hopefully it'll work. I'll give it a whirl.
Yes, you can export Omf. I'm not in front of Media Composer, right now but i think you have to switch to a sd-project and change the file format from mxf to omf in the media creation settings. Then, export an omf and consolidate to aif-c media.
www.film-editing.de
Looks like there's a script you can drop into premiere to enable aaf import:
http://labs.adobe.com/downloads/aafimport.html
and from there send it to audition. Maybe. :-)
Patrick: Looks like there's a script you can drop into premiere to enable aaf import: http://labs.adobe.com/downloads/aafimport.html and from there send it to audition. Maybe. :-)
Thanks for the suggestion, Patrick. I had previously tried that, but didn't have much luck with the AAF import. I'm not sure what the problem is. Gonna keep looking for a solution.
Thanks, Bolersch. In Media Composer 6.5, you can't just export OMF audio from an HD sequence. You have to convert your project to SD and change your media creation settings from MXF to OMF. This is a silly workaround. You should be able to just export an OMF, because not all Audio mixing software supports AAF the way ProTools does.
When I finally was able to export an OMF, the Avid told me there was an error with my OMF, because I couldn't export an OMF from a sequence with mixed framerates. I have mixed 24 fps and 25fps footage in my timeline. This would force me to either fix all the framerate issues beforehand or go AAF to Protools (which I don't have) or export entire tracks (which causes reduced flexibility).
So, I've learned that Avid doesn't play well with Audition (and most likely other DAWs) in general. Seems like it's really just geared to go to Protools and nothing else.
Audition works just fine with OMF2.0 (CS6). No problems for me. I'm exporting with MC6.
