Dear Avid Community,
I have a DNXHD185X commercial and I need to export it as ProRes 422HQ .mov from Avid.I am aware that the quicktime conversion causes a shift in gamma.But the alternative way that should work when MC 6 launched, also gives me a gamma shift.
Here is what I did:-Transcoded my final sequence to Apple ProRes HQ MXF (there is no option for Apple ProRes 422HQ, but I am guessing its the same thing)
-Exported the transcoded sequence same as source
The end result was a .MOV file with Gamma Shift (I checked it for differences by reimporting or AMA linking the file in Avid)Also when inspecting the file the codec was labeled as followed: "AVdn, Apple Prores 422 (HQ), Timecode" instead of "Apple Prores 422HQ"I tried exporting same as source with and without the "use of avid codecs" but they all result in Gamma shift.
What am I doing wrong?
UPDATE: When doing a mixdown in stead of a Transcode there is no gamma shift!Also when inspecting the exported file it is now labeled as: "Prores 422HQ, timecode" instead of that weird Avdn label.
I am happy I have found a solution, allthough I find it strange that a transcode to the same codec does not work for me.
