Hi all,
Is there any way within Avid FX to draw a custom shape to create an alpha like you can with the BCC make alpha? All I can find is set shapes like circles and rectangles etc.
When I try to draw a spline I can't seem to work out how to use that as a key.
Craig.
craig r harbour:Is there any way within Avid FX to draw a custom shape to create an alpha
Is this something like you are looking for, Craig?
http://www.screencast.com/t/l0pJU6Ontk
I animated it to show further possibilities
Regards,Douglas
[email protected]
Hi Douglas,
Not really what I'm after. I want an alternative to animatte but with the advantage of being able to move the newly created matte around the screen. BCC Make alpha does this which is fine if I have access to it but being a freelance editor you never know if the next suite you end up in is going to have BCC installed now that it has been removed from version 6, I can however be sure that Avid FX will be there.
The way I would do it With BCC Make Alpha is Make Alpha from Alpha, turn on pixel chooser and in PC region change shape to custom and then draw the shape I need.
If I try to do something similar inside Avid FX I can only go as far as getting custom shapes like circles and rectangles.
Hope that all makes sense.
Thanks in advance.
There is a way, and that way involves using the "Mask" tracks present on shapes in AvidFX. I just did a screencap with voiceoever showing what I mean here ;
http://www.borisfxresources.com/AvidForum/AvidFXmasks/AvidFXmasks.html
—————— Dirk de Jong BorisFX
Yup this is what I wanted to do, Thanks.
It will take a a bit of practice though to get my head a round it!
Thanks again,
craig r harbour: Hi Douglas, Not really what I'm after
Yes it was, Craig.
While I was asleep in Japan, Dirk did that useful quick tutorial (below) which actually describes the exact method I used in my demo above.
Thanks for filling in the gaps, Dirk.
PS. I cover quite a lot about using the spline tracks/spline objects etc. in some the tutorials on my site.Feel free to take a look.
