Latest post Mon, Aug 15 2011 3:27 PM by MichaelP. 4 replies.
  • Mon, Aug 15 2011 10:34 AM
    • Umut
    • Joined on Fri, Apr 30 2010
    • Istanbul
    • Posts 14
    • Points 150
    r3d folders scanned and not found! need help!!
    i got footage on my desktop.. and im scanning my folders with metafuze 2.5...
    red epic footage.
    but metafuze keeps failing finding the files...
    anyone that can help?
    might it be a matter of directory structure??
    thanks.
    amc 5.0, win7 home premium, sony vaio vpcf123fx,intel i7 q740, 6GB ram, nvidia gforce gt 330m [view my complete system specs]
    Filed under: , ,
  • Mon, Aug 15 2011 11:05 AM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
    • ! Avid Employee
      Avid Certified Instructors - Video
      Moderator: Film and 24p
    Re: r3d folders scanned and not found! need help!!
    I know Epic support is coming, but it may not be in the latest public release whcih would explaing not being able to see them.I need to confirm.
    Michael
    24p.com
  • Mon, Aug 15 2011 11:07 AM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
    • ! Avid Employee
    Also, what are you getting out of MetaFuze that you can't do in REDCINE X? REDCINE X exports native MXF/DNxHD with more metadata than is extracted from MetaFuze at this time. Available natively for Mac and Windows.
    http://reduser.net/forum/showthread.php?61183-REDCINE-X-Build-487...
    Michael
    24p.com
  • Mon, Aug 15 2011 3:10 PM In reply to
    • Umut
    • Istanbul
    • Posts 14
    • Points 150
    well couldnt figure out actually how to do that from redcine-x it will be my first job with it...
    i thought it was only for wieving and grading....
    so ill go for that now...
    still accepting any tips...
    thanks a lot....
  • Mon, Aug 15 2011 3:27 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
    • ! Avid Employee
    It is very straightforward. See:
    http://tinyurl.com/29ue8mm
    About halfway through it shows a REDCINE X workflow.
    Basically go to export
    make new setting. Select AFF/MXF. Select DNxHD frame rate and data rate. Then audio preferences. Then option like SMPTE contrain or full swing. Save.
    For each batch processed you will end up with a folder of MXF files (copy to your Avid MediaFiles folder). A folder of AAF files (drag and drop into your bin for automatic relink to media), and an ALE with all additional metadata (merge into existing master clips via ALE merge).
    Michael
    24p.com
