Latest post Tue, Sep 9 2014 12:34 AM by editor14. 4 replies.
  • Tue, Apr 12 2011 3:59 AM
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    PlayerHostThread::Stop PHT not alive anymore
    Anybody seen thi message before - I'm gettign weird hangs in MCA on a PC connected to Unity on fibre - will not respnd for 2 -3 minutes and then it will either recover or completely crash.
    Very frustrating as it seems to work fine for a while. Will play th same sequence on another client with no problems...
    John
  • Tue, Apr 12 2011 6:22 PM In reply to
    • Posts 11,452
    • Points 234,080
    Re: PlayerHostThread::Stop PHT not alive anymore
    Mondo
    How about some spec's here like what version of Unity - etc........
  • Wed, Apr 13 2011 1:21 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Yikes - it is about time I updated my specs!
    Will let you know when I've done it.
    John
  • Wed, Apr 13 2011 2:12 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    OK Updated specs - it is the first machine in the list that is playing up.
    Funnily enough I can't start up the display driver cotnrol panel extension to check the version so I'm goig to re-install the correct NVidia driver to see if that is an issue..
    thanks
    John
    John
  • Tue, Sep 9 2014 12:34 AM In reply to
    • editor14
    • Joined on Thu, Mar 17 2011
    • Posts 29
    • Points 315
    I have the same issue with my Mac Pro Online suite using a 10GBe direct conect.
    I dont think it is a server issue, I suspect a bad/damaged fibre cable. I hope I'm wrong.
