Latest post Wed, Apr 20 2011 3:13 PM by Jon Bagge. 4 replies.
  • Sun, Apr 3 2011 10:58 PM
    • Krishius
    • Joined on Wed, Oct 10 2007
    • Riga, Latvia
    • Posts 259
    • Points 3,735
    Exporting Avid Packed 10-bit from After Effects
    Hello!
    I have a composition in After Effects that contains a 10-bit video footage and I want to export it to Avid Packed 10-bit format for fast-importing into Avid.
    I've set the After Effects project to 16 bpp mode.
    When I add the composition to render queue and choose Avid Packed as the output codec , I can only choose millions of colors in color depth setting - the rest of possibilities are greyed and cannot be chosen.
    AFAIK, millions of colours only mean 8-bit actual output and for true 10-bit output trillions of colors setting is required.
    I've also noticed that from Avid codecs, trillions of colours can be set only for DNxHD X.
    Is there some trick that I've missed about exporting to Avid Packed 10-bit from AE or is it simply impossible?
    Thanks in advance!
  • Mon, Apr 4 2011 5:54 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,459
    • Points 98,560
    Re: Exporting Avid Packed 10-bit from After Effects
    Krishius:
    That's because DNxHD without the X is 8-bit only.
    Krishius:
    Guessing here, are you using a 10-bit or better otput format?
  • Mon, Apr 4 2011 8:20 AM In reply to
    • Krishius
    • Riga, Latvia
    • Posts 259
    • Points 3,735
    Well, Avid Packed is a 10-bit codec.
    P.S. Also checked Avid Packed RGB (which is also 10-bit) - the same thing - cannot choose trillions of colors.
  • Mon, Apr 4 2011 10:27 AM In reply to
    • fiendish
    • Posts 534
    • Points 6,505
    Indeed, Avid Packed is what the 1:1 10b resolution gets called outside MC. I have faced this problem before working in AE trying to get SD 10 bit renders out of it, in the end our only option was to render 16 bit TIFFs and import them into MC at 1:1 10b. Far from ideal. It has been raised before with seemingly no solution
    http://community.avid.com/forums/p/53867/301485.aspx#301485
    z840 dual E5-2667v3@3.20GHz / 64GB ram / Quadro M5000 / MC 2020.10 / BM Decklink Studio 2 // i7-2600k Home Build / 8GB ram / MC 2018.12 xw8600 Dual Quad... [view my complete system specs]
  • Wed, Apr 20 2011 3:13 PM In reply to
    • Jon Bagge
    • Joined on Sat, Jul 3 2010
    • London, UK
    • Posts 17
    • Points 225
    I have the same problem now.  I'm pretty sure I've been able to make this work some time ago, probably on CS3 with an older version of the packed codec.
    My project is 16-bit.  I've selected Avid Packed codec with correct settings (Interlaced, 601/709).  AE won't allow me to select trillions of colours.  It would seem the packed codec is reporting to AE that it's 8-bit only.
    Avid MC6 @ Dell Precision T7500, 2xXeon 5580 3.2Ghz, 48GB RAM, Quadro FX3800, Win7 Pro x64 [view my complete system specs]
    Jon Bagge
    Editor/Animator - Avid - FCP 7 - After Effects
