I could have sworn this can be done (im sure it can, i must have missed a step) Trying to import a 60 frame into a 30 frame project, tells me i can not. I am using MC 5. (academic version)
Create a 60 frame project and import your 60 frame content there. Then, use the "open bins" function inside your 30 frame project to open the bin from the 60 frame project. The system will apply a timewarp algorithm to the 60 frame content to convert it.
thanks again Larry!
You're quite welcome, Toby. Always happy to help out.
Larry Rubin: Create a 60 frame project and import your 60 frame content there. Then, use the "open bins" function inside your 30 frame project to open the bin from the 60 frame project. The system will apply a timewarp algorithm to the 60 frame content to convert it.
Mark Job
Larry, while i got you here, i have another question, ive been having a heck of a time capturing hdv (JVC GY-HD200, through firewire) as soon is i hit record in the capture tool, i get a "Caputre abotted due to lack of progress" but there is not lack of progess i can control my vtr through the capture tool perfect. then as soon as i hit record i get that error.
riestererproductions: Larry, while i got you here, i have another question, ive been having a heck of a time capturing hdv (JVC GY-HD200, through firewire) as soon is i hit record in the capture tool, i get a "Caputre abotted due to lack of progress" but there is not lack of progess i can control my vtr through the capture tool perfect. then as soon as i hit record i get that error.
I've seen this before and it's normally an issue with the capture resolution or frame rate not matching the actual DV stream coming down the firewire. Sometimes it''s the avid end set wrong but I've even had it with the camera having been set to downconvert from HDV to DV by mistake.
Check everything matches.
T 07581 201248 | E [email protected]
Hi Mark,
Mark Job:it does not work like the manual states it does.
Can you point to a particular page of the manual that's wrong? I can let the right people know something needs to be fixed if I have something more specific.
ciao,Carl
I've also seen capture aborted due to lack of progress errors when only marking in on the capture tool and leaving the out point undefined.
ahhhh, i didnt even know i had to mark in and out on the capture tool, just thought i could hit "record" and thats it. also i noticed the timecode caption on the capture tool does not count down (or up) its frozen, as is the green timecode indicator, which is suppose to be blinking. i did eventually capture something but when i played it back it was in slo-mo and out of sync
i have another question, how come mpg files can not be imported?
How about another thread for that topic (or a feature request in the feature request forum)?
Steve
______________________
www.nelliedogstudios.com
