http://community.avid.com/blogs/buzz/archive/2011/02/22/avid-helps-bring-viewers-to-the-frontline-in-egypt.aspx
wanted to bump this up because it's a pretty amazing feat and I'm surprised that no one has commented
This is a pretty incredible article and story.
Pheral: This is a pretty incredible article and story.
Mark Job
Mark Job:I am assuming all elements (Other than still images), were transcoded upon ingest to some flavour of DNxHD
The stills were done in After Effects and so would've also ended up imported into Avid as DNxHD.
I just sent an email to my friend Chad, who was the lead editor on this, to see if he would be willing to relay some of the technical details.
Impressive!
Kenton.VanNatten:The stills were done in After Effects and so would've also ended up imported into Avid as DNxHD.
Kenton.VanNatten:I just sent an email to my friend Chad, who was the lead editor on this, to see if he would be willing to relay some of the technical details.
I'm not sure what the price on that used Adrenaline is, I would consider waiting until after v5.5 is released and look into getting the AJA I/O Express. It'll let you capture over HD-SDI, plus MC v5.5 will give you new features and tools.
Kenton.VanNatten: I'm not sure what the price on that used Adrenaline is, I would consider waiting until after v5.5 is released and look into getting the AJA I/O Express. It'll let you capture over HD-SDI, plus MC v5.5 will give you new features and tools.
Hi everyone, thank you for the praise for this project. It was a very challenging undertaking and required a team effort, frequently around the clock. Our Post Supervisor, Chris Fournelle is working on a detailed account of the workflow to be shared with Avid & the community. Also, I believe they're going to have Chris do a presentation at NAB and have some of our sequences and media on-hand to demonstrate.
I'll try to address some of the questions that I've seen thus far in the discussion. Media type: We cut the whole thing in DNX-145 and its PAL equivalent. PAL media was imported / captured into a PAL project then moved over to the offline project. All four of the offline editors worked in the same Avid project, splitting our bins into folders.
I didn't do the pictures in After Effects this time. In the first segment we had the larger aesthetic issue of contending with the shaky, rough footage acquired in Cairo. We usually aspire for a very smooth, classy feel to our pictures, interviews, etc. Things made in that style looked very strange when placed in the verite-style footage though. So I made a 'handheld' effect using the 'Shake' effect from Sapphire. I put this effect on all our interviews and most still images. On interviews I also added a push using the resize effect. I felt that this gave the interviews a similar feeling to the rest of the footage. For the stills I just imported them at DNX-145 and animated them with understated moves using the 3D Warp.Because of the fast timetable, with each choice I wanted to weigh the potential issues I might cause down the line so I tried to keep everything as 'within the box' as much as possible. In other words I didn't want to have to answer questions about missing pan & zoom pictures in the middle of the night.
Other assorted details: the Canon f footage required us to buy the camera to capture. Most footage was file-based so the greatest technical challenge of the whole project was to was to copy over the footage (which was hastily put onto a drive in the middle of the chaos over there), keeping it in a coherent system so we could tell what it was and when it was filmed. But the most challenging issue for me was that, once all of this happened and it was in the project on the unity... it was still in arabic... So for any sound-ups between interviews, people chanting, etc. I would have to call a translator into the room and make sure that they were actually saying something relevant, finishing thoughts, etc.
Anyway, hopefully this answers some of the questions and provides a little more insight into the process/workflow. When Fournelle has the more thorough explanation I will forward along. Otherwise, I will keep an eye on this board and answer anything else to the best of my ability.
Awesome thanks Chad!
I got wrapped up in the story, so obviously that means you did your job well. Maybe we should consider having you guys do a demo for the BAVUG?
Chad Ervin:Other assorted details: the Canon f footage required us to buy the camera to capture.
Mark,
Whenever possible we used the native source codec as long as possible--Sony EX, XDCAM, HDV, etc. The footage is going to change codecs enough through the broadcast chain so we prefer to transcode as little as possible. With those codecs Avid can't play natively, we transcoded to a DNxHD resolution. The exact resolution was dependent on the source mb/sec, frame size, fps, and avid project it was ingest into. With this much footage and the amount of rooms needing to work in the same project, AMA was only used in the ingesting process.
We mastered on HDCAM 1080, 59.94 and made our digital QuickTime master at DNxHD 145. Other digital versions for the web, YouTube, etc, were made from that master QuickTime file. Each version has its own specification.
Chris Fournelle
Post Production Director/Frontline OutPost
Hi Chris: I'm a little unclear as to how you edited HDV shot @ Canon 25 F ? Did you have to transcode the Canon HDV 25 F PAL to DNxHD 145 ? Media Composer Can't ingest from HDV tape via Standard FireWire without crash recording, because capture from source tape TC at 24 F/25F doesn't work, so how did you specifically deal with the Canon HDV footage ? If you had ingest stations setup which had Adrenalines or Nitris DX boxes, then you could possibly capture in realtime via HD-SDI or HDMI (If the Canon HDV camcorder was a model which had HD-SDI or HDMI output jack). I'm very interested to know in specific detail how your post dealt with anything shot in Canon 24 F or 25 F HDV.
With those particular shots, I ingested the tapes with a PAL version Canon XHG1 into a 1080 50i project via firewire with my MacBook Pro. I was connected to Unity with Port Server Pro. I could only get a valid signal by setting my frame size to 1440x1080 and using the HDV resolution. I didn't have any issues with the TC.
Because of the difficulties in using the camera as a deck, I didn't log it, but just set an in-point and left the out empty. Normally we would try to ingest in shorter clips so there wouldn't be time-code drift, but we've always had trouble using this format. This frame rate also forced us to ingest via firewire rather than HDSDI and RS-422 control.
We haven't seen a lot of Canon f frame rates so my experience with it is limited. In the two or three cases, this is how we did it. The other instances were with 30f
One note about the entire project: Contrary to normal practices, we ingested everything at HD resolution so there wouldn't be any down-time with the conform. Since moving to file-based acquisition, we've spent a lot more time trying to re-ingest/conform in our normal offline/online model. We didn't have the luxury to wait until the program was finished to up-rez material, and I believe had we, the program broadcast would have been in jeopardy.
