Latest post Wed, Feb 23 2011 2:20 PM by doc.phibes. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Feb 22 2011 3:55 PM
    MC 5 Windows 7 64bit and Power scheme warning
    Ok so whats the solution to removing the power scheme warning at launch?
    I've solved it on 2 machines but have a 3rd machien that defies fixing.
    I've created a power plan called Always On and set that to max performance.
    The console command powerman doesn't seem to do anything.
    So how best to not get that nag every launch?
  • Tue, Feb 22 2011 4:11 PM In reply to
    • scocklin
    • Maryland
    • Posts 673
    • Points 8,020
    Re: MC 5 Windows 7 64bit and Power scheme warning
    Just did a clean install to Windows 7 64 bit from Vista64 so I'm resetting some of my settings, what worked for me in removing those pesky messages although not nearly so bad as Vista64 was.  Go to search programs and files, type in Power Options select  High Performance go into change plan settings and select Never, Never for display and Sleep. Hope this helps!
    HP Z800 2x 3.46GHz Hex Core X5690, 96GB Ram, Windows 10, Samsung SSD 1TB, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K, Avid MC-2018.12.7 , MacBook... [view my complete system specs]
  • Wed, Feb 23 2011 11:47 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,420
    • Points 97,425
    Pat, I had a similar problem some years back.  It turned out to be caused by a wrong BIOS setting.  Try checking whether you have power management active in the BIOS.
  • Wed, Feb 23 2011 12:03 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 948
    • Points 12,125
    Pat,
    make sure the power management does not switch off disks or other equipment (as said by scocklin) select never in the various categories. Also make sure that no screen saver is active.
    Joachim
    Joachim Claus
  • Wed, Feb 23 2011 12:56 PM In reply to
    Joachim Claus:
    Pat,
    Joachim
    Yes I tried that. Initially it comes set to balanced. I changed it to high perfomrance and then modified it to have everything never sleep and nothing less than 100%
    That didn't work it still moans on Avid launch. So I then made a new plan called always on and set that to be 100% and never sleep and active and Avid still moans.
    Checked BIOS and power management is on.
    What's strange is it moans about Home/office power management profile and there isn't even one!
  • Wed, Feb 23 2011 2:20 PM In reply to
    • doc.phibes
    • Joined on Mon, Jul 3 2006
    • Germany
    • Posts 57
    • Points 685
    I've excperienced such a problem on some XP machines before... the easiest way for me to fix it was to copy the powerconfig-settings from a "good" system to the one that moaned. you said you have 2 systems that behave fine? so you can try this:
    -Go to one of your "healthy" systems and launch the Registry Editor (Start Menu->Run->type
    in "regedit")
    -go to the HKEY_CURRENT_USER directory
    -Go into the Control Panel directory and find PowerCfg
    -Right click on PowerCfg and select export
    -You should see a radio button selection on the bottom of the window for Export
    Range.  Make sure that Selected branch is active
    -Export the reg file and bring it to the other system
    -On the other system, simply open Regedit and select import from the file menu.
    -Navigate to your healthy PowerCfg registry file, and hit OK
    The error should go away once you have done that.  You may or may not need to reboot the system for the fix to work.
    I've done this successfully various times on XP32bit systems, never tested it on Win7 but it's probably worth a try!
    best of luck!
    HP z400, 12 GB RAM, Nvidia Quadro4000, Win7x64, MC5.5 Nitris DX / Supermicro X8DAE, Dual 6-core XEON 3,33GHz, 24GB RAM, Nvidia GTX285, Win7x64, Symphony... [view my complete system specs]
    “Technology is a word that describes something that doesn't work yet.”  (Douglas Adams)
