Latest post Sun, Feb 20 2011 7:25 AM by oze. 17 replies.
  • Wed, Feb 9 2011 1:22 AM
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    Arri Alexa and Arriraw workflow . . ?
    Hi, I'm familiar with Metafuze and Red but have my first Alexa job (a commercial) coming up and thought I should find out about the workflow. I am guessing that MC5 will not mount the files via AMA so transcoding in MC is a non-starter, so I am assuming that Metafuze will work with the Arriraw format and that the work-flow is basically the same as Red was handled pre MC 5. We will be wanting to grade directly off the Arriraw files so it's essential that the final EDL be able to address folders as reel numbers and proper timecode.
    Am I correct? I would be most appreciative of any help or guidance.
    2017 27" iMac i7 4.2, 2TB PCI memory, 64GB RAM, OS 10.13.6, MC 2018.10 [view my complete system specs]
  • Wed, Feb 9 2011 2:48 AM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
    • ! Avid Employee
      Avid Certified Instructors - Video
      Moderator: Film and 24p
    Re: Arri Alexa and Arriraw workflow . . ?
    MetaFuze supports Arris D21, but not ArriRAW from Alexa at this time.Otherwise, yes. It would have been a similar workflow.
    Michael
    24p.com
  • Wed, Feb 9 2011 3:17 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    So what's the best solution? Rushes through a post-facility by the sound of it or forget Arridraw altogether and transcode Pro Res 422 via AMA and then grade off Pro Res 444 files . . ?
  • Wed, Feb 9 2011 3:52 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,181
    • Points 50,460
    Well, as of a couple of days ago, ArriRaw was not offically available.  Only the ProRes files.  Check with the DP to make sure.  Arri has let a FEW cameras out that are Raw enabled.
    I just finished a spot which was from Alexa.  Everyone thought it would be Raw files until right before the shoot when they realized that ProRes was all that was available.  Lots of confusion about this right now.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Wed, Feb 9 2011 8:05 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    jef:
    Jef
    Thanks Jeff, I'm looking into that now. I think you may be right. Did you end up finishing from the 4444 files?
  • Wed, Feb 9 2011 11:01 AM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
    • ! Avid Employee
    You will also need to process outside the system if shooting with LogC on your ProRes files.
    Michael
    24p.com
  • Wed, Feb 9 2011 6:31 PM In reply to
    Alexa can only deliver ProRes encoded Quicktime files at this time. Those will play back in real time without importing in MC5. On older versions you will have to import first, or you could use MetaFuze to offload this process to other machines.
    Igor Ridanovic
    www.HDhead.com
  • Wed, Feb 9 2011 6:39 PM In reply to
    MichaelP:
    Hi Michael,
    What type of outside processing workflow would you currently recommend?
    Thx
    Job.
  • Wed, Feb 9 2011 7:06 PM In reply to
    • Tommyp
    • Joined on Wed, Jan 25 2006
    • Ann Arbor, MI
    • Posts 74
    • Points 915
    MichaelP:
    Michael
    Not really, you just have to color the footage in MC to have it look nice.  If it was recorded in LogC, it will appear very flat, but there wil be a lot of range to push the color where you want it to go. MC can certainly do that. -  (This is all for the offline) So you can directly use the LogC ProRes 4444 QT's if you want.
    Some people are recording ProRes on the in-camera card as LogC and then connecting a KiaPro and recording a Rec709 output for their dailes, then conform to the LogC files once they have picture lock. A very effective workflow. That is how we are handling our current Alexa shot jobs.
    Many paths to the same destination.
    Tom
    Filed under: ,
  • Wed, Feb 9 2011 7:52 PM In reply to
    Tommyp:
    Which is pretty nasty as soon as you matchframe or want to compare an unused (ungraded) take to a used (graded) one. I used to work that way on my first Red projects, but if possible, would prefer to avoid this method.
    Tommyp:
    I've always felt that is very tricky, as you never know 100% sure that what you have on one medium is what you have on the other. Years ago a colleague did an HDCAM feature where they co-recorded on DVCAM. They ended up having to exchange a few shots that had been recorded on DVCAM, but that were not on the HDCAMs.
  • Wed, Feb 9 2011 8:02 PM In reply to
    • Tommyp
    • Ann Arbor, MI
    • Posts 74
    • Points 915
    I hear you Job. All valid concerns. I'm used to cutting on DS, so we just set a souce side CC and that problem goes away. Not sure if you can do something similar on MC? I'm sure someone will let me know if you can.
    As for the dual record, it's been pretty solid. (good DIT's I guess) On the flip side of that is the option to record Rec 709 ProRes 422 QT's on the camera and rec LogC to a HDCAMSR recorder on the output.
    The other option is to wash them through something like Clipster and add a 709 LUT, which is what they were getting at earlier.
    Tom
    Filed under: ,
  • Wed, Feb 9 2011 8:13 PM In reply to
    • jef
    • Maryland
    • Posts 4,181
    • Points 50,460
    oze:
    We offlined in MC with DNx copies of the shoot footage which had been treated in our DaVinci Resolve with the offical Arri LUT for LogC.
    I then published an EDL for which was used by the Resolve Colorist to conform and correct shots directly from the LogC nonLUT footage.  They made DPX files.  I imported those into DS for effects and final finish in a 4:4:4 23.98 sequence.  I then converted to 4:2:2 59.94 and SD.
    Some bumps along the way based on current file based workflow issues between MC and DS.  But still it seemed like the highest quality.
    Jef
    Jef Huey
  • Wed, Feb 9 2011 8:53 PM In reply to
    Tommyp:
    There's source based CC in Symhony (which I also own), but it is applied in the timeline, not to the actual source side.
    Tommyp:
    good DIT's I guess
    Yeah, they are absolutely key.
    Thanks for your tips. I'll explore preprocessing in Clipster. I don't think they'll want to opt for an SR recorder.
  • Wed, Feb 9 2011 10:50 PM In reply to
    • OliverPeters
    • Orlando, FL
    • Posts 506
    • Points 6,800
    Job ter Burg:
    Actually I think he means effects applied to the source before being edited to the timeline, just like in FCP. Ultimately Avid will probably need to add AMA source settings to ProRes or ARRIRAW files, just like with RED footage.
    - Oliver
  • Wed, Feb 9 2011 10:55 PM In reply to
    OliverPeters:
    Yeah, I got that.
    OliverPeters:
    OTOH, why wouldn't Arri work on that themselves? It requires some AMA plugin design. Today I heard that 80-90% of the national advertising here in Holland has switched from 16/35mm to Alexa.
