Good mornig everyone, i need help for the files .mts from the camera panasonic AG3da1.
meta fuxe not supported the files .mts.
I have to use the files steorographic for my production, but if you do not use meta Fuze to convert the material for sterographic from mts files...can someone help me?
Conversion for mts?
thanks to all
Alex
Try Cineform's Neo 3D - you will be amazed
I'm trying, I was hoping that Avid had implemented the mts files. is a great program but you have to convert the files twice .... thanks a lot
Avid does support mts files to some extent but in this case you have seperate recordings for left and right eye which need to be processed in a special way (eg. as 3D). MC doesn't support this regardless of this being mts or another format. Neo 3D makes it possible for Avid to edit a QT movie (linked by AMA) which is actually a 3D file thanks to the underlying technology of Cineform. This allows for much greater flexibility, for example you can switch between left eye, right eye, anaglyph etc... mode LIVE - so MC will just update the video and doesn't notice the difference. Very nice technology and a very nice solution for 3D.
I tried the program of CineForm, is fantastic. My question is as finalized by the Avid Nitris mounted?
cinetica video: I tried the program of CineForm, is fantastic. My question is as finalized by the Avid Nitris mounted?
I don't understand the question...
Igor Ridanovic
www.HDhead.com
I'm sorry, I wanted to know, once the project finished 3d, how do I export the project to maintain the 3D?
Considering that the film will be for use at the cinema
thanks
That depends on the finishing system you are using and on what the film lab is expecting from you. Most likely you would deliver left and right eye DPX sequences (two times what you'd normaly deliver).
I finalize the film on Symphony Nitris system with HP workstations Z400. Thanks for the advice and happy new year
You can view the video in 3D on a monitor with Nitris? You must use an external encoder 3d?
