Latest post Thu, Jan 20 2011 5:03 AM by Joe M. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Dec 6 2010 6:12 AM
    • Joe M
    • Joined on Sat, Sep 9 2006
    • Southwestern part of US
    • Posts 952
    • Points 12,785
    What is this error message? Bug?
    I was opening up pop up windows... and, after about 8 pop ups... this showed up:
    The pop up windows are not useable after this error message showed...
    WinXP,ASUS W6T6 WS Rev.,Intel i7 3.2Ghz8X32,6G Corsair DDR3(low lat.),Quatro FX 3800(190.38),Adaptec 5405 RAID 0 SAS-2 Stripes 2x15K RPM Fujitsu 300G ea... [view my complete system specs]
  • Mon, Dec 6 2010 7:10 AM In reply to
    • mvegas
    • Posts 1,555
    • Points 17,980
    Re: What is this error message?
    Found on the KB using DSM as the keyword in the search Error: Exception: AMPI subsystem error, ErrorMessage:DSM error code eDSMError_SendMessageErr,|AudioMixPathComponent::DisconnectOutputSection in AudioMixPath.cpp: 1007 [368731] An error occurs when working with Audio in Media Composer 5, NewsCutter 9, and Symphony 5
    Why do I get the following error when working with audio in MC 5, NC 9, or Symphony 5:
    This error can occur when using Media Composer 5, NewsCutter 9, or Symphony 5.
    1. When Using the Sound Soap Pro RTAS Plugin
      Using the Sound Soap Pro RTAS Plugin in a sequence can cause this error. Please use the AudioSuite to apply this plugin, and od not apply it via RTAS.
    2. When fast editing in the timeline
      Sometimes doing fast editing (scrubbing, JKL, etc.) in the timeline or source monitor will cause this error. This issue was resolved in MC 5.0.3, Symphony 5.0.3, and NewsCutter 9.0.3
    3. During launch of the application.
      This error can occur at the "Initializing AudioSuite plugins" stage of launch. There are a number of fixes for this issue. Please see AMPI Sub System Error while Launching Media Composer, Symphony, or NewsCutter [377091]Also, in some instances on the Mac, this has been resolved by uninstalling Media Composer, repairing disk permissions with the Disk Utility, and re-installing.
  • Mon, Dec 6 2010 2:38 PM In reply to
    • Joe M
    • Posts 952
    • Points 12,785
    Well... close... but no cigar.
    As I noted earlier... this occurs when opening up the 7th (not the 8th as I initially posted) pop-up monitor.
    I am running MC 5.0.3 ...
    Can anyone test this issue out with MC 4.0 version.... or, an MC version that is using the most recent patchs installed?
    To duplicate the error... simply open up 7 or more pop-up monitors in succession...
    I have my "Bin Settings - Current" ...set to... "Double-click loads object in:"   ...as....
    "New Pop-up Monitor "  - not Soruce or Record Monitor.   I double click the bin video frame to open the pop-up monitors.
    I would like to know if this is a bug... or related my system configuration.
  • Mon, Dec 6 2010 2:47 PM In reply to
    Running Newscutter 8.0.2 (equivalent to MC 4.0.2)
    Set bin settings for "double click opens as new pop-up monitor". Opened a dozen pop-up monitors in a row - no error screen.
  • Mon, Dec 6 2010 3:03 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,971
    • Points 70,590
    Re: What is this error message? Bug?
    I get the error message on the 11th pop up... but by clicking OK I can continue my work, opening the 12th pop up I get the error message again, and so on. MC 5.0.3.5
    Symphony 24.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro T400 [view my complete system specs]
    peace luca
  • Mon, Dec 6 2010 4:36 PM In reply to
    • Joe M
    • Posts 952
    • Points 12,785
    luca.mg:
    I can continue work in the timeline... but, I can not continue using the pop-up monitors...Have you tried to use the pop-up monitors in an editing fashion... such add IO points in the pop-up monitors?
  • Tue, Dec 7 2010 12:41 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,971
    • Points 70,590
    Yes I can continue to work, on opening a new clip I get the error message, as well as I occasionally get it while editing, it's annoying and shouldn't happen, but by clicking OK I can continue to work.
    peace luca
  • Wed, Jan 19 2011 7:48 PM In reply to
    • Jessie
    • Joined on Wed, Jan 19 2011
    • Posts 5
    • Points 45
    I was wondering if you ever found an answer to this error message.  I just recently updated/upgraded etc to MC 5.0.3 and get this error message about the 11th pop up. I can click okay and keep working but once I click on another clip the error message comes back up.
    I did notice if I change my setting back to opening the clips in the source/record monitor it doesn't happen but personally I don't like to edit that way.
    HPz400 Workstation Windows 7 Pro Service Pack 1 Avid 7.0.3 Mojo DX [view my complete system specs]
  • Thu, Jan 20 2011 5:03 AM In reply to
    • Joe M
    • Posts 952
    • Points 12,785
    Jessie:
    The Exception: AMPI error .... with regard to opening up multiple pop-up windows in Script Bin... issue has not been resolved that I know of...
    What I know is that this error was also present in MC 5.0.0.  However, I have not tried any patches with MC 5.0.3 to see if this is still an issue.... my best guess is that this was not fixed by any patches, but based on the problems I have seen with patches lately... I have decided to wait until there is a problem with MC5.0.3 that I can't live with before I apply any patches.
