Latest post Thu, Feb 10 2011 7:44 PM by Kenton.VanNatten. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Thu, Dec 2 2010 6:09 AM
    • Joe M
    • Joined on Sat, Sep 9 2006
    • Southwestern part of US
    • Posts 952
    • Points 12,785
    How do you remove a project listed in the Select Project window at startup
    How do you remove a project listed in the Select Project window at startup...?   I have already backed up/copied the project removed all master clips, precomputes, attic files.  I just don't want the project to show up in the Select Project window at startup.
    Never mind... I found it in the manual... after looking for over half an hour... geees...
    You pick the video project in the Select Project window and hit delete key.
    WinXP,ASUS W6T6 WS Rev.,Intel i7 3.2Ghz8X32,6G Corsair DDR3(low lat.),Quatro FX 3800(190.38),Adaptec 5405 RAID 0 SAS-2 Stripes 2x15K RPM Fujitsu 300G ea... [view my complete system specs]
  • Thu, Dec 2 2010 6:53 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: How do you remove a project listed in the Select Project window at startup
    Yes, that was also what i wrote into your thread the 29 th
    Projects are deleted by pressing the delete button on a highlighted project form the " open up project" window
    http://community.avid.com/forums/p/91538/520401.aspx#520401
    Tomas
  • Thu, Dec 2 2010 12:32 PM In reply to
    Alternately, you can delete the specific project folder from the master "Avid Projects" folder on your C: drive. And don't forget to clean out the attic!
  • Fri, Feb 4 2011 6:31 PM In reply to
    Can all of that NOT be accomplished by the Media Tool?
    HP Z400, Windows 7, Avid Nitris DX, Media Composer 5.5, Ikegami GFCam HDS-V10, Panasonic P2 AG HPX-170 [view my complete system specs]
  • Fri, Feb 4 2011 6:40 PM In reply to
    "... Can all of that NOT be accomplished by the Media Tool? ..."
    It's a tool for media management, not project management.  So, no.  However, Media Tool can help you delete all the "media" for a project.
    (wwld)
  • Fri, Feb 4 2011 6:44 PM In reply to
    Details on using the media tool.
  • Fri, Feb 4 2011 6:54 PM In reply to
    Thanks for clarifying.  Can you also point me to a download for MC v5.0.3 user guide?  We upgraded via download and didn't receive any hard or digital copies of the manual.
    Lindsay
  • Fri, Feb 4 2011 7:38 PM In reply to
    At the moment, this is all I can find. I'm still searching....
  • Sat, Feb 5 2011 2:18 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,954
    • Points 70,425
    As of MC 5 printed manuals are not provided anymore.
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Sat, Feb 5 2011 4:27 PM In reply to
    luca.mg:
    That is correct, but a qualified search on the Knowledge Base should easily find it, and right now it does not. The web team is currently working on that issue.
  • Sat, Feb 5 2011 4:39 PM In reply to
    • Vidiot Tech
    • Joined on Thu, Apr 6 2006
    • South Carolina
    • Posts 155
    • Points 1,835
    I don't delete old projects from the listing.
    With Avid shut down, I navagate in Windows to the "Avid Projects" folder. I create a folder called "Old Projects" inside the Avid Projects folder, then I just move the projects I don't need to the "Old Projects" folder.
    The "Old Projects" folder (or any other folder inside the "Avid Projects" folder) doesn't show up in the "Select Project" window on startup.
    So the projects are still available if needed, yet don't clutter up the Projects listing.
    System Specs: Dell M90, 4GB Ram (3GB Avid Enabled), nVidia FX 1500 w/ driver 8.4.2.9, MC 2.8, QT 7.2, External WD 750 GB eSata Drive [view my complete system specs]
    Steve Godsey, CLVS
    Some producers are like slinkies: Completely useless, but you can't help but smile when you push one down the stairs.
  • Sat, Feb 5 2011 4:44 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,954
    • Points 70,425
    Larry Rubin:
    Yes it should, an assistant of mine downloaded it not so long ago. To remain topic: I never trash old projects but I archive them.
    peace luca
  • Sat, Feb 5 2011 4:50 PM In reply to
    Also, when removing or archiving old projects, don't forget to clean out the attic!
  • Sun, Feb 6 2011 12:12 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,460
    • Points 98,575
    I hate cleaning the Attic.  You get so dusty...
    I'm also one that manages project folders from Explorer, for exactly the same reason as the two posts above.  That way you can keep a backup should you need it.
  • Sun, Feb 6 2011 4:23 PM In reply to
    • DFW Hokie
    • Plano, TX
    • Posts 272
    • Points 3,670
    I believe the MC5 manuals can be found here (It's where they are on my machine.):
    C:\Program Files (x86)\Avid\Avid Media Composer\OnlineLibrary\DOCS
