Latest post Thu, Nov 25 2010 6:36 PM by adamsonn. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Nov 25 2010 4:26 PM
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Sorenson 6.5 issue
    Hello
    I know this is not a Sorenson board but I wondered if anyone has had this issue.
    I have a Quicktime movie file output from MC5 it is SD PAL widescreen (1024X576).
    When I import this into Sorenson5 and I change the aspect to 16:9 the file displays correctly and the aspect ratio proportions are correct.
    The same file in Sorenson 6.5 opens as 4:3 with the right hand part of the video cropped, and when I change it to 16:9 in the Aspect window it just makes the cropped picture wider.
    Anyone experiencing the same problem? Or know how to correctly display PAL widescreen QT files correctly in Sorenson?
    Neil
    MC6 machine: Intel Core i7 Asus P8-H67 64 bit Motherboard 1*1Tb SATA drive - partitioned to C (OS and programs) and D (data) drive 1*1TB SATA drive... [view my complete system specs]
  • Thu, Nov 25 2010 6:36 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Re: Sorenson 6.5 issue
    I have tried to import some other 16:9 files and they seem to work.
    I believe this is a codec issue and is caused by the way that Avid exports widescreen PAL QT files
