Latest post Sun, Dec 5 2010 7:51 PM by TVJohn. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Nov 23 2010 4:49 PM
    • denniscasey
    • St. Paul, Minnesota
    • Posts 667
    • Points 8,495
    Upgrade to Sorenson Squeeze 6.5: Benefits/Problems?
    What experience do forum members have with Sorenson Squeeze 6.5 used with MC5.0? Creative Cow sent an offer from Sorenson to upgrade from Squeeze 5.0 to 6.5 for $199 until November 26 (claims quite a savings). So even though I have not even used Squeeze 5.0 included with Liquid to MC production pack I would like opinions to help me determine if this $199 is a deal I should not pass up (for later use primarily)?
    I searched forum and last post I found was January 26, 2010 saying Squeeze 6 was not qualified for used with Avid MC and it appeared there were problems using Squeeze 6 with MC at that time.
    However, now Sorenson website cites 6.5 designed for use with Avid MC (and other NLE) and several benefits if you upgrade from 5.0 to 6.5 including faster encoding.  Acknowledge Sorenson "bias" but Creative Cow member also had pretty favorable review of 6.5 vs Squeeze 5.0.
    Question is could 6.5 benefits apply to me (enough to spend $199)? At moment it does not appear integrated workflow or broadcast benefits mentioned for Squeeze 6.5 would apply to me. I am basically just advanced hobbyist for fun and also doing some volunteer editing (Liquid was perfect for me) but when I move into HD (maybe with DSLR from Canon or Sony) I wonder if Squeeze 6.5 encoding and maybe some other features will benefit me working in MC 5 environment?
    MC6.5.2 SYSTEM: Asus P6X58D Premium; Intel i7-930 2.8 Ghz; PNY FX1800 GPU;500 GB RAID 1 System Drives; 1 TB RAID 0 Media Drives; 12 GB triple channel RAM;... [view my complete system specs]
  • Tue, Nov 23 2010 5:12 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: Upgrade to Sorenson Squeeze 6.5: Benefits/Problems?
    I like Squeeze 6.5 and use it quite a lot, both for creating web files, BD files and converting to Avid codec files
    Tomas
  • Tue, Nov 23 2010 8:53 PM In reply to
    • denniscasey
    • Posts 667
    • Points 8,495
    Tomas, thank you for timely and current comments.  Dennis
  • Wed, Nov 24 2010 2:42 AM In reply to
    • sam the sham
    • Apple Valley, Ca
    • Posts 924
    • Points 11,790
    I received the same email from Sorenson and it was somewhat misleading I think. It stated :
    "Upgrade to Squeeze 6.5 from ANY previous full version of Squeeze for only $199!"
    Actually if you have Squeeze 6 which comes with MC 5 Production Suite the upgrade is free. It might pay just to buy whole Suite 5 from Avid....
    MC 6.0.3.1 thank you very much, FCP X v.10.2.3, MAC Pro, 2 @ Intel Quad-Core Xeon 2.4 GHz,(Westmere),12gb 1066mhz DDR3 ram, ATI RadeonHD 5870 1GB. 3@ 1TB... [view my complete system specs]
  • Wed, Nov 24 2010 10:42 PM In reply to
    • denniscasey
    • Posts 667
    • Points 8,495
    Good info, Dan. With all the deals, rebates, upgrades and so forth one can lose track.  However, I only have the production suite which came with the Liquid to MC4 offer and it came with Sorenson Squeeze 5.  I used the "free" download upgrade to go from MC4 to MC5.  I will look at Avid options to buy the "new" Production Suite (for MC5).  Dennis
  • Fri, Nov 26 2010 12:51 PM In reply to
    • SussexJohn
    • Joined on Wed, Dec 21 2005
    • Brighton, England, UK
    • Posts 556
    • Points 7,735
    mjolnarn:
    Hi Tomas
    Like many others I have Squeeze 5.  What would you say the main benefits of upgrading to 6.5 have been?
    MC5.0.3.8, win7 64 pro, Matrox mini 02, Gigabit X58A mb, i7 Q930 2.83GHz, Nvidia Quadro FX 1800, 6Gb 1066 ram, 2 1Tb video HD, 500gb 7200 system HD, 1tb... [view my complete system specs]
    SussexJohn
  • Fri, Nov 26 2010 12:59 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    I have to admit that I hardly remember Squeeze 5 but from bad memory I think that it is that the H 264 part  has been improved and faster rendering speeds, I might forget one or a couple of things..
    Tomas
  • Fri, Nov 26 2010 4:24 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    I have just taken the upgrade offer and installed 6.5 - the new features that I have found to be beneficial are:
    1. Better structure for pre-set settings (i.e there are now settings for devices, Discs, Editing, Formats, Web) etc.
    2. There seem to be a number of Avid specific settings that I have yet to try
    3. My best discovery was that the Editing tab's preset of "DV Stream" produces a good quality file in a format that Liquid seems to like -I have consistently battled to get MC5 output into Liquid effectively, and have never found the best way to convert the Mov file to a format preferably AVI but DV will do and to use that as import into Liquid.
    Normally I encode for DVD using Avid DVD / DVD IT HD but I am going to try Sorenson Mpeg2 / DVD encode preset and see what output that gives
    Other than that I cannot verify if the encoding is better or faster or more up to date than 5 but given that I spent money on the upgrade I choose to believe that it is vastly superior.
    Neil
    MC6 machine: Intel Core i7 Asus P8-H67 64 bit Motherboard 1*1Tb SATA drive - partitioned to C (OS and programs) and D (data) drive 1*1TB SATA drive... [view my complete system specs]
  • Fri, Nov 26 2010 11:10 PM In reply to
    • denniscasey
    • Posts 667
    • Points 8,495
    Neil, I like your "vastly superior" approach to purchases (a great antidote when I am confronted with any lingering buyers remorse for purchases I have made). Plus the great savings you got adds even more to the "vastly superior" mantra. Enjoy, Dennis
  • Wed, Dec 1 2010 2:37 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,862
    • Points 24,410
    Other than the upgrade to Squeeze 6, what other upgrades are included in the current production suite that weren't included in the MC4 Boxed edition?  In other words, if Squeeze 6 is all you get for $295, it would be cheaper to just get the update from Squeeze for $199.
    Denny
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Wed, Dec 1 2010 11:39 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Denny, if you maybe thought of buying a new computer, maybe a laptop, it might be handy to use the SW licensing options for deactivating and activating and also have one more bundle with new fresh license codes on the other system.
    Tomas
  • Wed, Dec 1 2010 3:40 PM In reply to
    • Haze
    • Posts 764
    • Points 10,205
    denniscasey:
    I wouldn't spend $200 upgrading a program that I never use.  That's just me.
    Avid DS 11 | Z800, Symphony 6.5 | HP xw 8600, MC 6.5 | HP Z400, Unity Storage [view my complete system specs]
  • Wed, Dec 1 2010 5:14 PM In reply to
    • denniscasey
    • Posts 667
    • Points 8,495
    Haze, To clarify, although I bought MC when Avid dropped Liquid I still primarily use Liquid for SD and have not used Squeeze in MC.  In light of savings provided by Sorenson upgrade offer my question was forward planning for when I migrate to HD and MC5--I wondered if forum members using MC5 for HD work found Squeeze 6.5 that much better than Squeeze 5.0.  If 6.5 was much better then I would spend $199 today rather than $499 or so for 6.5 in future.  Dennis
  • Thu, Dec 2 2010 3:59 PM In reply to
    With 140 euros you get both TMPGEnc Xpress and Authoring Works.
    When you try those, you wont' change them for anything else.
    Their quality and speed is very good.
    You will see then, that Squeeze is a way overpriced.
    I never use it anymore.
    And to state the obvious here:
    this is just my approach to that matter.
    I don't say is the right one. Yes
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Sun, Dec 5 2010 7:51 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,382
    • Points 54,130
    I agree with George, Squeeze is very expensive, the TmpGe products are more modestly priced, and product improvements are often and usually not charged for.
    Although Authoring Works is not as elegant in some ways as Dvdit (Avid DVD) is is a solid program that works well, and I use both.
    Using MC 20.10. Win 20H2  Avid FX6.4, Vegas Pro 18/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
