Latest post Sun, Nov 21 2010 5:55 AM by Editmvp. 3 replies.
  • Wed, Nov 17 2010 11:01 PM
    • Lior
    • Joined on Thu, May 21 2009
    • Israel
    • Posts 87
    • Points 1,240
    small change of functionality, makes me disappointed .
    Hi ,
    Last night I applied to my system the Patch 5.0.3.6 .
    Before applying the patch I was able to lasso clips or audio only of certain clip on the timeline and delete them using the delete key.the system could clear only those clips w/o dragging the rest of the footage on the right side of the timeline.
    Now, after installing the patch, the system clears the clips but drags the clips placed after to the point where the deleted clip were begining.
    Example: Clip 1 : Clip 2 : Clip 3
    Lasso the audio of clip 2 and hitting delete, use to clear only the audio of clip2.
    Now what happens is this, when I'm lasso the audio of clip 2 and hit delete, the audio of clip 3 dragged to the place where the audio of clip 2 have been.
    Its like Ctrl+X always active and what I used to work with was more like Lift but w/o the need to select tracks and I/O points.
    Tried to find settings to change this new behavior . no luck , could not find any.
    I hope you understand me. english is not my language and its hard for me to express myself accurately  in words.
    Lior.
    Mother Bd. : Asus Z170A CPU: Intel I7 6700K O/S: Windows 7 ultimate 64Bit Memory: 32GB DDR4 GSkill Display Adapter: QuadroFX3800 by PNY. SoundCard... [view my complete system specs]
  • Fri, Nov 19 2010 8:41 AM In reply to
    • daapap
    • Germany
    • Posts 544
    • Points 7,185
    Re: small change of functionality, makes me disappointed .
    in the timeline settings, second tab, there is a setting concerning the timeline's default behaviour. switch it to "overwrite". (not at the Avid now, so i do not remember the exact phrase.)
  • Sat, Nov 20 2010 3:54 PM In reply to
    • Lior
    • Israel
    • Posts 87
    • Points 1,240
    Thanks but its already on Overwrite.
    But , It seem to be a developed behavior . when I start with a fresh timeline that does not happening.
    Working more and more brings this phenomena back to life.
    this all happened since patch 5.0.3.6 installed  . damm...
  • Sun, Nov 21 2010 5:55 AM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 179
    • Points 2,100
    The 5.0.3.6 patch has been removed from the download center due to many issues it created. You should revert back to a previous working patch.
    Primary System: Media Composer Ultimate 2024.6 | Avid Artist DNxIO | iMac 2020 i9 10-Core 3.6/128GB/2TB-SSD/Radeon Pro 16GB / OS 14.6.1 | Artist Color... [view my complete system specs]
