Latest post Wed, Apr 6 2011 4:06 PM by Aliocha. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Sep 26 2010 6:31 AM
    • Nick
    • Joined on Mon, May 3 2010
    • Scotland UK
    • Posts 213
    • Points 2,725
    Firewire Problem
    I am having a problem with outputting down the firewire to DV decks. I can capture fine without any problems but when I enable the output to DV function, play the timeline and monitor the deck all is fine for about 15 seconds until the sound goes and the picture breaks up. Sometimes it comes back again and sometimes MC freezes when it happens. I have tried different firewire drivers and I read that the legacy drivers were best with Windows 7, I have also tried 2 different decks and different drivers on each of those also. Digital Cut also isn't happy. I am using the onboard firewire on the front of the HP Z800 and I have also tried a PCI fireiwre card. The project is standard definition DV PAL, 25i, have also tried different projects and footage and firewire cable and get same problem. Both decks are set to the EE function and still have problems even if in record. Have also tried turning on and off 'realtime encoding'
    I have been through all the Avid configuration guidelines for the computer and have tried running the decks as Generic DV devices and giving them named settings both on 'OHCI' and 'no port'
    There is obviously something seriously wrong if a top end machine that is capable of editing HD footage cannot even output SD DV over firewire.
    HPZ800, X2 Intel Xeon X5650 Six Core, Nvidia Quadro FX4800, 48GB RAM, Nitris DX, MC 8.5.2 Windows 7 Pro [view my complete system specs]
  • Sun, Sep 26 2010 7:23 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,375
    Re: Firewire Problem
    Just wanted to confirm that it works well with MC 5,0,3,2 for me, hadn´t tried this for a while, source is Avid 1:1 10 bits and I am doing a digital cut out to my little Sony HC 90e, settings RT DV25 , ignore time
    Tomas
  • Sun, Sep 26 2010 7:25 AM In reply to
    • Nick
    • Scotland UK
    • Posts 213
    • Points 2,725
    Thanks for that. Will try outputting on the exact same settings and see what happens.
  • Sun, Sep 26 2010 12:36 PM In reply to
    • Nick
    • Scotland UK
    • Posts 213
    • Points 2,725
    Same problem I'm afraid. I have a feeling this is something to do with the actual computer drivers/hardware. Is anyone else using a Z800 and outputting down the firewire successfully?
  • Sun, Sep 26 2010 5:46 PM In reply to
    • Nick
    • Scotland UK
    • Posts 213
    • Points 2,725
    bump
  • Mon, Apr 4 2011 9:05 AM In reply to
    • Aliocha
    • Joined on Sat, Dec 4 2010
    • paris
    • Posts 13
    • Points 135
    hi,
    exactly the same issue... And the same computer. did you solve this? or not?
    I also have a lot of problems with the MBOX mini, with a lot of scratches during playback. It really hurts the ears...
    Tell me you sole this... thanks
    alexis
    Imac pro 2017 2,3GHz intel xeon w 18 128 Go 2666 MHz DDR4 Radeon Pro Vega 64 16 Go Blackmagic extreme 3 Catalina 10.15.7 Avid 2020.9 [view my complete system specs]
  • Wed, Apr 6 2011 4:06 PM In reply to
    • Aliocha
    • paris
    • Posts 13
    • Points 135
    hello,
    i have fixed myself the issue, with the help from the "avid configuration guidelines hpz800"
    Now, everyhing is perfect.
    Bye
