Latest post Thu, Sep 30 2010 7:16 AM by Lemuriatv. 12 replies.
Page 1 of 1 (13 items)
  • Sat, Sep 18 2010 11:18 AM
    • Lemuriatv
    • Joined on Wed, Mar 5 2008
    • Czech Republic
    • Posts 229
    • Points 2,810
    MC5+Matrox MXO2mini in multicamera mode
    Has anybody same experience with Matrox MXO2mini as me? When I switch to multicamera mode picture on monitor Eizo Flexscan HD2441W looks much worse (as in medium draft mode) then in normal edit mode. Project is PAL 50i, and of course video quality icon is still full green.
    CPU Intel Core i7-7820X, MSI X299 SLI Plus, 64 GB RAM DDR4-2666 MHz,NVIDIA Quadro K5200, 4 TB for video (2 TB in Raid + 2 TB on SSD), Win10Pro, MC 8.4... [view my complete system specs]
  • Sat, Sep 18 2010 11:22 AM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    Re: MC5+Matrox MXO2mini in multicamera mode
    Also I am disappointed that there is not  picture from record monitor on previewmonitor but source monitor (quad or nine split picture).
  • Sun, Sep 19 2010 6:27 PM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    Nobody has the same experience?
  • Mon, Sep 20 2010 10:40 AM In reply to
    Jip, same here. I've had issues trying to cut 720p with the MX02 attached to a laptop-based system. In the end I turned off the MX02, went to 1394 and everything worked perfectly again. I should mention that I was editing with media on a external drive connected via eSATA...don't know if that had something to do with it. But it was a minor issue in my oppinion, as I said I fixed it by just turning the MX02 off and turning it back on once I finished the multicam edit.
    Avid Media Composer 2020.4 HP ZBook 17 Gen3, i7-6700HQ CPU @ 2.60Ghz Win 10, 64GB RAM [view my complete system specs]
  • Mon, Sep 20 2010 10:53 AM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    CorneScheepers:
    I have to do the same - edit multicamera with MXO2 turned off. It is terrible bug in MC5, isn´t it?
  • Mon, Sep 20 2010 11:04 AM In reply to
    I'm on a laptop most of the time, so its less of an issue for me. But I suppose it can be annowying if you're on a desktop system. Fortunately once you've cut the multicam sequence, you can turn the MX02 back on for grading etc where you do need your client monitor.
  • Mon, Sep 20 2010 11:08 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Lemuriatv:
    I just finished a 4 hours HD multicam with 5,03,2 4 cams and 8 audio channels without any problems.
    Tomas
  • Mon, Sep 20 2010 11:44 AM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    Mjolnarn,
    as described at your  system spec you are using mac system not pc. Do you have another matrox driver as me (I am on pc) or the same (included in avid instalation, ver. 2.2.0.11)?
  • Mon, Sep 20 2010 11:58 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    If you look closer into my specs you will notice that we are using similar hardware on the PC side besides that you are using a better videocard than I.
    But, about the drivers, you caught me there, wasn´t my intention at all, I seem to just have became one of those " works for me " posters, I just remembered that I updated to the latest MM driver a while ago on the PC side to have AE and the capturing working better, driver is 3,01.
    It is however not, I repeat not, recommended to use that driver with Media Composer, at least not with the current versions,  the previewing will not work well in SD mode
    Tomas
  • Mon, Sep 20 2010 1:16 PM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    Any recommendation from Avid moderators about this problem and driver?
  • Wed, Sep 29 2010 3:19 PM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    No recommendation from Avid moderators ? Somebody has the same experiance in multicamera mode (SD)?
  • Thu, Sep 30 2010 1:20 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,418
    • Points 97,405
    Lemuriatv:
    There's obviously a misunderstanding here.  The moderators are here to moderate the forums, and are not necessarily Avid employees.
  • Thu, Sep 30 2010 7:16 AM In reply to
    • Lemuriatv
    • Czech Republic
    • Posts 229
    • Points 2,810
    I know jwrl, but they are more experienced Smile
