Latest post Fri, Dec 31 2010 4:23 AM by jwrl. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Thu, Sep 16 2010 8:38 PM
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Quicktime export - fixed yet?
    Hello
    I am still unable to export to Quicktime files in MC50.3.2 - this is a rudimentary requirement and it is something that needs to be prioritised as urgent.
    Or did this get fixed and I missed it?
    MC6 machine: Intel Core i7 Asus P8-H67 64 bit Motherboard 1*1Tb SATA drive - partitioned to C (OS and programs) and D (data) drive 1*1TB SATA drive... [view my complete system specs]
  • Thu, Sep 16 2010 8:54 PM In reply to
    Re: Quicktime export - fixed yet?
    Wow. So many details missing from this post.
    I don't even know where to start.  it's like saying to a mechanic "My car makes a noise, why doesn't Toyota fix it?"
    I often find that having the correct version of QT and sometimes creating a brand new Avid User helps with QT Export problems.
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Thu, Sep 16 2010 8:58 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    This is because it has been reported in a number of other posts - sorry I should have attached this those posts as well. But then again which one...
    Here are some of the other posts:
    http://community.avid.com/forums/t/85101.aspx
    http://community.avid.com/forums/p/86355/489107.aspx#489107
    http://community.avid.com/forums/p/85403/482948.aspx#482948
    http://community.avid.com/forums/t/85006.aspx
    The error message is GenVideoExpConsumer: Preload()has a null input Probably failed negotiation.
    I am sure that means a lot to you
  • Thu, Sep 16 2010 9:32 PM In reply to
    Those posts are from other people, what are you specifically doing when this error comes up? What format are you trying to export? What codec? Where are you sending it to? What is the source material in the timeline?
    Media Composer 2019.11 Home-built Windows 10 Pro Asus Z87-A Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz, 3101 Mhz, 4 Core(s), 4 Logical Processor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Fri, Sep 17 2010 2:52 AM In reply to
    • DonR
    • Irving, Mexas
    • Posts 225
    • Points 3,130
    Have you clicked the "safe mode" thiing in QuickTime "preferences?"
    SuperMicro Superworkstation 7045A-T Computer Hardware: 1-Supermicro Sys-7045A-TB 4U Xeon 1333FSB FB-DIMM 6XSATA Motherboard X7DAE 2-Intel... [view my complete system specs]
  • Fri, Sep 17 2010 2:32 PM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    Changing  "safe mode" thiing in QuickTime "preferences?" doesn’t help.
    This work-flow work fine with MC 3.6 but not MC 5.0.3,.
    Format setting: 25i PAL
    Capture from DV-tape, Res: DV 25 420 MXF
    Clip Video become: DV 25 420 i(PAL)
    Export As: QuickTime Movie, same as Source, no problem.
    In order to import new format like AVCHD we dared to upgrade (fearing that any upgrade would course troubles, it proved to be right):
    WIN 7 64bit
    QT v7.6.6 as recommended by AVID will not install on a 64bit platform so it had to be QT 7.6.7
    MC 5.0.3
    Now when trying to export to QuickTime Movie, same as Source
    MC 5.0.3 will report error code:
    Exception: GenVideoExpConsumer::PreLoad() has a NULL input. Probably failed negotiation.
    We are a film school with 13 AVID MC5 and 115 student stalled.
    Allan
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
  • Fri, Sep 17 2010 3:32 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Yes, the information provided above is pretty much my workflow - the export to quicktime when same as source is selected seems to be the problem.
    Except I am on Windows XP 32 Bit professional and my version of QT is the recommended 7.6.6 version and my Nvidia Quadro FX18 drivers are those recommended by Avid.
  • Fri, Sep 17 2010 3:47 PM In reply to
    • mgschrey
    • Joined on Wed, Sep 15 2010
    • Posts 4
    • Points 50
    I'm having the same problems when export Quick Time Same as Source.
    I just put a new video track on top of the edit and fill it with an unrendered effect, like resize, which has no effect on my edit. After this, the export seems to be working with my engine.
    Kind regards
    Marcus
    MC 5.0.3.2 w\Adrenaline + DNxcel Board, 2xE5640+12GB RAM, Nvidia FX1800 190.38 Win7 Pro 64-bit QT 7.6.6
  • Fri, Sep 17 2010 7:30 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Hello Marcus
    That workaround seems to work! - But just a quick question - what made you try that?
    I am all for trying things and looking for workarounds but I have to say I dont think I would ever have thought of doing that to see if it worked!
    Anyway this seeems to be a common enough problem for Avid to resolve as a fix hopefully sooner rather than later.
    Regards
    Neil
  • Sat, Sep 18 2010 11:37 AM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    Hello Marcus
    Your workaround work! You are a genius!
    Thank you
    Let’s hope AVID fix this buck. It is embarrassing to teach it for my 115 student.
    This buck appears when captured DV-tape, to Res: DV 25 420 MXF are attempted exported to QT.
    It does not appear when consolidated from P2 to Res: DV 25 420 MXF or
    AVCHD to Res: DV 25 420 MXF.
    Allan
  • Tue, Sep 21 2010 9:03 AM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    Buck in MC 5.0.3 preventing export (QuickTime Movie same as Source) codec (DV 25 420 MXF). Reporting error code: Exception: GenVideoExpConsumer::PreLoad() has a NULL input. Probably failed negotiation.
    Marcus wisely suggested a workaround, by placing an un-rendered resize effect on a new video track, and it will work.
    The drawback is export time is increased to 6.6 x sequence time.
    The advantage using (QuickTime Movie same as Source) export is the fast export time.
    Using MC 3.6 the export time is 0.4 x sequence time.
    This workaround will cause the export time to be 13 time slower!
    I hope that AVID are aware of this buck
    Allan
  • Wed, Sep 29 2010 5:05 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,340
    Adding my voice to this thread, now that I have found it!  The Exporting from MC5.0.3 has become a nightmare.  Not only does the "same as source" mode produce error messages, it also trunkates seemingly OK timelines so that shots are missing.  The adding of a filter, as posted above, increases export times to a point where it is more than just painful.
    Then there seem to be inconsistancies in the QT DV PAL export settings where a file created at native dimensions 720x576 works OK, the same settings put into 1024x576 produce interlacing issues...  I'm also exporting "upper field first" in the 720 setting to create a working file where I alway used to export lower field first as it was DV PAL???
    I have wasted more time exporting and re exporting in different settings trying to create consistent results under 5.0.3 than I have on any other MC version...
    MC8.10 Win 7 64 with Dongle, Dual 10 core Xeon, Quadro K4000, Adaptec RAID 5-8x3TB, External TB2 4x3TB, 64G RAM, BM Intensity Pro 4K. NewBlue Titler 6... [view my complete system specs]
    Vote 1 - Dongles.
    UME an old engine, now with 4K, mags and furry dice....
  • Wed, Sep 29 2010 7:50 PM In reply to
    • DonR
    • Irving, Mexas
    • Posts 225
    • Points 3,130
    Do you have the same problems when in NTSC rather than PAL?
  • Mon, Oct 4 2010 10:27 PM In reply to
    • Yuri
    • Joined on Thu, Jun 22 2006
    • Moscow
    • Posts 17
    • Points 255
    Hi!
    Try AvidMediaComposerPatch 5.0.3.4
    My DV PAL 420 footage now can export QT mov Same As Source !
    Good luck!
    Asus_X99-E_WS i7-5960X 32Gb_DDR4 GTX750Ti GTX1070 BM_DecklinkHDExtreme3D+ Win10_1809,MediaComposer Subscribe 2019.12 [view my complete system specs]
  • Tue, Oct 5 2010 5:09 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Yes and no - The latest patch does remove the appearance of the original error message - but it does not fix the problem of not being able to export a QT reference file for me:
    1. If I export a QT reference file with an Audio mixdown (absolute must as if you dont all your audio work is ignored) I get an error message that says : "Exception PGLUE-IMPOLITE_PORT_NUMBER" (I was aware that port numbers could be polite / impolite / rude or anything).
    2. If I export without audio mixdown - then the error that I get is "Track 1 not found"
    Any advice on resolving these would be greatly appreciated - nearly finished a big job for a mining company and will need to export it for encoding shortly and am not sure what I am going to do if I cannot export it!!!
