Latest post Mon, Sep 6 2010 7:37 AM by mjolnarn. 8 replies.
Page 1 of 1 (9 items)
  • Sun, Sep 5 2010 11:48 AM
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Boris FX message after upgrading to FX1800
    Hello
    I have upgraded my MC5.03 (with the patch applied) to a Quadro FX1800 graphics card - 768Mb ram
    I have also ensured that I am at Quicktime 7.6.6 (aka the recommended version) and my Nvidia drivers are at 190.38 so all seems to be in spec.
    But when I open an MC5 project that has Boris BCC 3Dtext effects I get this message - see attached file.
    My screen resolution is the native 1680 x 1050 and worked with a Geforce 7600 card so am not keen on changing to a lower resolution - I would rather go back to an unsupported card.
    Also the BCC 3D text does not appear in the effects window and does not render.
    I have also tried this with the other Nvidia drivers supplied by Avid - (182.65) - same problem
    Anyone know what this means.
    Neil
    MC6 machine: Intel Core i7 Asus P8-H67 64 bit Motherboard 1*1Tb SATA drive - partitioned to C (OS and programs) and D (data) drive 1*1TB SATA drive... [view my complete system specs]
  • Sun, Sep 5 2010 12:20 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: Boris FX message after upgrading to FX1800
    Not at my sys right now Neil , but about this,
    be sure that filtered layer ( or something similar ) is selected, the default might be the underlying track
    Tomas
  • Sun, Sep 5 2010 12:37 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Tomas
    The correct tracks are enabled.
    Neil
  • Sun, Sep 5 2010 12:47 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Yes, of course, thinking closer of it, you should always see the rext no matter what setting you have.
    Will take a look at this in a couple of hours if noone else is able to assist before that
    Tomas
  • Sun, Sep 5 2010 1:41 PM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Just an update - If I apply the BCC extruded text directly onto a clip - the entire clip goes black and there is no display at all in the monitor window.
    And the first time I click on the effect the message box above appears
    It appears that most of the other non-3D BCC effects work just fine.
    Is there any way to test the GL settings inside of MC?
    Inside of Avid FX the hardware tests all pass fine.
  • Sun, Sep 5 2010 1:47 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Go to the Video display settings in your control panel and check that your card is enabled for rendering
    Tomas
  • Sun, Sep 5 2010 4:22 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    So I am at my sys now and all works as expected, my dual screen res is 1280 x 1024 , has always been, even in the Liquid days.
    We seem to have different drivers, strange, I am also using the 190 version of the drivers.
    If your error message says that 1600 is max for quadro cards and dual screens, so be it but I find it strange that you not even are seeing the text.
    You can also see in my snapshot what my 64 bits OS does with the cards mem, it is the same card.
    Tomas
  • Mon, Sep 6 2010 6:42 AM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Hello
    How does one go about enabling rendering in the control panel?
    Most of my options in the Nvidia control panel are not available unless I specifically create an application profle - but even then there is no "enable rendering option"
    Just an update - I reformatted my C drive and then rebuilt the editing workstation from scratch.
    This has resolved the 3D BCC effects problem - but the message above does come up when I scrub over or add the Boris 3D effect, so there must be a way to make enable OpenGL by default.
    Neil
  • Mon, Sep 6 2010 7:37 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Media Composer Control Panel - Video display output
    I have never touched those settings
    If you still have 1650 as res the message about telling that 1600 is max seems to be correct
    Tomas
