Latest post Thu, Aug 25 2011 5:04 PM by Marty. 15 replies.
  • Fri, Aug 6 2010 9:17 AM
    • jok71
    • Joined on Mon, Oct 29 2007
    • Posts 39
    • Points 505
    Matrox MXO2 mini playback problem
    Using MC 5.0.2 with the Matrox MXO2 mini on a 17" MBP. The MXO2 seems really nice except for one problem: whenever I hit stop, the video freezes on the correct frame for a fraction of a second, before jumping ahead a few frames. This is very annoying as it makes it impossible to hit the correct frame.
    I have seen similar behaviour with the Mojo SDI, but only on the client monitor, and never in the source/record monitors. With the MXO2 mini it happens in all monitors (at least they are in sync!) If I switch off external monitoring (with the Client Monitor toggle), the problem goes away.
    Is anyone seeing the same behaviour? Are there any workarounds?
    MC 2019.12 - Windows 10 Professional - HP Z4 - Quadro P2000 - 32GB RAM - Intensity Pro 4K [view my complete system specs]
  • Fri, Aug 6 2010 9:44 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,320
      Moderator: MCA Mac
    Re: Matrox MXO2 mini playback problem
    I'm seeing it too.  I don't see the problem when using a Mojo DX, if you can call that a workaround.
  • Fri, Aug 6 2010 6:05 PM In reply to
    • jok71
    • Posts 39
    • Points 505
    hbrock:
    Smile
  • Fri, Aug 6 2010 8:25 PM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 943
    • Points 11,035
    try using desktop play delay for some frames. i know, it's a different setting for firewiredevices only but i remember that i played with that and it became better. you can even turn it back to zero after the bug goes away, i think.
    all different setups in various editing suites. my own: MC 2018.2, OSX 10.12.6, iMac (Retina 5K, 27-inch, 2017), 4,2 GHz Intel Core i7, 40GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
  • Sat, Aug 7 2010 7:18 AM In reply to
    • jok71
    • Posts 39
    • Points 505
    Thanks, I will try your suggestion as soon as I am back on the Avid.
    EDIT: Tried it, doesn't help Sad
  • Sun, Sep 5 2010 9:13 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 943
    • Points 11,035
    I used the Matrox MXO2 Mini, today and had the same problem.
    When you hit stop, the picture/blue position bar jumps 1-2 frames ahead.
    I also don't see the full quality picture when I pause. Looks like only one field.
    Mojo SDI and FSP works better, is it a known issue? Did you find a solution?
    I'm using it in a 25p PAL project on CRT monitor (s-video), now.
    It works good with FCP so I guess it should be a driver/setting problem, not the hardware itself.
    www.film-editing.de
  • Mon, Sep 6 2010 5:47 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Bloersch:
    The coordination between my eyes, brain and fingers have never been enough good to be able to do this in a 25th part of a second, I usually step one frame at the time or use slowmo when getting close to the desired frame, are you saying that it jumps one or two frames after that you have removed your finger from the key?
    Tomas
  • Mon, Sep 6 2010 7:55 AM In reply to
    • jok71
    • Posts 39
    • Points 505
    No solution yet I'm afraid, but I posted about the problem in the Matrox support forums. They promised to look into it so hopefully we'll see a fix in a future version of the drivers.
    BTW, are you seeing the same behaviour in FCP?
  • Mon, Sep 6 2010 5:40 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 943
    • Points 11,035
    You don't need good coordination for that. You will definitely see/feel it, when you hit pause it stops for a short amount of time, than it jumps ahead, maybe 2 frames, maybe one. it's not only the one or two frames, it just don't feel accurate you always have a small delay that don't feel good when you want to find the right place to edit.
    Yes, it works very accurate in FCP so I hope a new driver will be the solution.
    www.film-editing.de
  • Mon, Sep 6 2010 5:41 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 943
    • Points 11,035
    Can you ask again in the Matrox Forum?
    www.film-editing.de
  • Mon, Sep 6 2010 5:50 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 943
    • Points 11,035
    Do you also recognize the poor image quality on parked frames?
    For me it looks like one field only and the Matrox setting for scrub & pause makes no difference.
    www.film-editing.de
  • Tue, Sep 7 2010 8:39 AM In reply to
    • jok71
    • Posts 39
    • Points 505
    Bloersch:
    I have not noticed this, but then again I have only used my Matrox for offline editing of DV PAL material.
    I have asked for an update on the Matrox forum, let's see what they say.
  • Sat, Sep 11 2010 8:30 PM In reply to
    • Marty
    • Berlin, Germany
    • Posts 943
    • Points 11,035
    I worked with FCP / Matrox, today.
    It immediately stops at the right frame and the parked frame looks great but you have a delay when you start playing, especially backwards and forward, again. Overal it feels a bit slow and sluggish. But it was ProRes HQ HD on MacBook Pro, could be also the performance...
    I think, my old Mojo SDI with Firewire (PAL only) stills works best for me and Fullscreen Playback without client monitor.
    But Matrox works direct with Expresscard, so it should be much faster, I hope new drivers will help.
    www.film-editing.de
  • Thu, Apr 21 2011 10:50 AM In reply to
    • Euchrow
    • Joined on Sat, Apr 15 2006
    • Brussels, Belgium
    • Posts 268
    • Points 3,530
    jok71:
    No news on a solution for this problem ? Still present in 5.51 with the latest Matrox drivers.
    Symphony 2019.6 on Mac Pro Westmere 3.33Ghz 6 core, 48Gb Ram, Nvidia GTX 980, High Sierra 10.13.6, BMD Ultra Monitor 2019.6 on MacBook Pro Retina 2018... [view my complete system specs]
  • Thu, Apr 21 2011 10:55 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Euchrow:
    jok71:
    On my system Avid has fixed this on the PC side, still remains to be fixed on the Mac side
    Tomas
