Latest post Thu, Apr 30 2020 5:00 PM by George Angeludis. 799 replies.
Page 50 of 54 (800 items) « First ... < Previous 48 49 50 51 52 Next > ... Last »
  • Wed, Sep 6 2017 5:00 AM In reply to
    GH5 4K 25p mp4 (lpcm) 10bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate by Avid Generic plugin:
    Failed.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Sep 6 2017 5:42 AM In reply to
    GH5 4K 25p mov 10bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate by QT plugin:
    Failed (green screen at AMA and at transcoded file).
    I have managed to transcode other 10bit mp4(lpcm) file by Avid Plugin at another project but the file was shorter.
    Desktop PC
  • Wed, Sep 6 2017 6:13 AM In reply to
    GH5 4K 25p mov 8bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate by QT plugin:
    Completed.
    Desktop PC
  • Wed, Sep 6 2017 6:23 AM In reply to
    Re: MC5 Diary
    So as far as GH5 1.1 firmware 5 min 4K 8 bit or 10 bit footage (mov or mp4 lpcm):
    Avid Generic Plugin:
    GH5 4K 25p mov 8bit 5 min transcode to DNxHR SQ as keep source frame rate:
    Failed.
    GH5 4K 25p mov 8bit 5 min transcode to XAVC 4K Intra CBG Class 300 as conver to project frame rate:
    Completed.
    GH5 4K 25p mov 10bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate:
    Failed.
    GH5 4K 25p mp4 (lpcm) 8bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate:
    Completed.
    GH5 4K 25p mp4 (lpcm) 10bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate:
    Failed.
    QT plugin:
    (I have managed to transcode other 10bit mp4(lpcm) file by Avid Plugin at another project but the file was shorter.)
    Completed.
    GH5 4K 25p mp4(lpcm) 10bit or 8bit couldnt be linked by QT plugin.
    I hope firmware 2.0 coming out at the end of September will solve some issues.
    Desktop PC
  • Wed, Sep 6 2017 12:35 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,423
    • Points 15,660
    Re: MC5 Diary
    Good quick test.
    I'm afraid it's more of an Avid Generic plug-in problem.
    Firmware 2.0, as far as codecs are concerned, only opens up other possibilities.
    V.
    AVID MC2020.08, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 442.50, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Wed, Sep 6 2017 1:06 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,295
      Moderator: MCA Mac
    Re: MC5 Diary
    Thanks Much George!!
    So the short story is:
    10-bit only supported by Avid generic plug-in. No support in QT at all. Very short transcodes may work (same as XAVC-S). Long transcodes fail. In general, transcodes fail.
    8-bit needs Convert to Project frame rate to transcode.
    QT plug-in does not support MP4 files (which is interesting as the QT library most definitely does).
    Dave S.
  • Wed, Sep 6 2017 4:58 PM In reply to
    Re: MC5 Diary
    I read that the new firmware irons some issues with all the major NLE's and with Avid that Panasonic drivers
    and codecs always get well. However we do as much as we can from our side to help the nonstop Avid's
    programmers to do their best as they ALWAYS do.
    GH5 is an affordable yet superb CINEMA camera that many will work or already are working with.
    I thank you Dave and everyone else here.
    And our queen M of course.
    Desktop PC
  • Tue, Sep 19 2017 2:43 AM In reply to
    Re: MC5 Diary
    It seems that all mp4 files longer than 4-5 minutes cant be transcoded at 8.9.1 with Avid Generic plugin.
    So it's not a case of GH5 files or DJI but of every H264 file.
    Turning the files at DnxHD or HR resolution (with another app) can allow MC see them, link them
    and transcode them.
    Desktop PC
  • Tue, Sep 19 2017 2:08 PM In reply to
    Re: MC5 Diary
    The problem is on 4K files and not on HD.
    Desktop PC
  • Tue, Sep 19 2017 2:42 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,295
      Moderator: MCA Mac
    Re: MC5 Diary
    I've heard back from support. They're working on fixing the MP4 issues. Hopefully this will cover both the transcode issue as well as the 1-frame off issues for both MP4 and XAVC-S.
    Dave S.
  • Wed, Sep 20 2017 6:39 PM In reply to
    Re: MC5 Diary
    I am sure they will fix it Dave. Thank you.
    Desktop PC
  • Tue, Sep 26 2017 5:05 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,295
      Moderator: MCA Mac
    Re: MC5 Diary
    8.9.22 is now released, and it fixed the transcode bug for XAVC-S, which is also MPEG-4 based. Hopefully it's fixed for the GH5 as well. I don't know about the 10-bit issue.
    Dave S.
  • Tue, Sep 26 2017 5:19 PM In reply to
    Re: MC5 Diary
    Bug Number: MCCET-2027. In some instances, transcoding long H.264 media using the Avid Generic plugin resulted in an exception error.
    You beat me to it David. Let's try it now. Thank you for getting this bug to Avid engineers.
    However this wasn't a problem with GH5 but with many mpeg4 files (DJI also).
    P.S. Anyone who is using a 2000D with Media Composer but in generally on his system,
    you should now that is EOL. The best replacement I think is P2000.
    Desktop PC
  • Fri, Sep 29 2017 12:22 AM In reply to
    Re: MC5 Diary
    Off topic Big Smile
    GH5 Firmware 2.0.
    Desktop PC
  • Fri, Sep 29 2017 6:08 AM In reply to
    • Vilem
    • Prague
    • Posts 1,423
    • Points 15,660
    Re: MC5 Diary
    George Angeludis:
    Off topic Big Smile
    GH5 Firmware 2.0.
    Yeah, I've already installed it. Smile
    My Slow Cards on 4K ALL-I. Hmm
    V.
