Latest post Thu, Apr 30 2020 5:00 PM by George Angeludis. 799 replies.
Page 49 of 54 (800 items) « First ... < Previous 47 48 49 50 51 Next > ... Last »
  • Tue, Sep 5 2017 7:31 PM In reply to
    Re: MC5 Diary
    My beloved David's (Wink) request is a command. As soon as I finish transcoding at the project I will do so.
    You want a 30minutes GH5 (mp4 or mov) file? At 8 or 10 bit? I am on PAL Land (25p/50Hz).
    Do you want me to use NTSC settings for both GH5 and MC?
    (P.S.>I did get the errors you mentioned at DJI files when using the "wrong" plugin which in that case
    was Avid Generic plugin. Also I don't know why but the trick with transcoding to the project's format helped too).
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Tue, Sep 5 2017 7:59 PM In reply to
    David I got that error but from what I understand is not connected with 8/10 or other options of the codec
    but PERHAPS on the duration as you say (?). However I dont have any file longer than 3 minutes on the list.
    What I test now is the files from GH5 and the files from G7.
    My suspicion is that some of them as DJI files are like to use QT plugin and others Avid Generic.
    Not all plugins can be used for everything as it seems.
    Desktop PC
  • Tue, Sep 5 2017 8:07 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,427
    • Points 15,690
    Re: MC5 Diary
    I have one set of 4k 50p long 32minutes. I'll try to transcode it.
    V.
    AVID MC2020.10, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 442.50, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Tue, Sep 5 2017 8:24 PM In reply to
    • Vilem
    • Prague
    • Posts 1,427
    • Points 15,690
    Re: MC5 Diary
    Generic plug-in, after a while the same mistake as George ...
    The QuickTime plugin is still running. I will let you know.
    V.
  • Tue, Sep 5 2017 8:30 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,783
    • Points 48,355
      Moderator: MCA Mac
    Re: MC5 Diary
    I don't think the error will happen with the QT plug-in. It seems to be an MP4 container issue only.
    Dave S.
  • Tue, Sep 5 2017 8:36 PM In reply to
    • Vilem
    • Prague
    • Posts 1,427
    • Points 15,690
    Re: MC5 Diary
    DStone:
    Looks like it.
    The source is the same "mov" linked once with the Avid Generic plugin, the second time with the QuickTime plugin. Avid Generic fails. Qt is still running.
    V.
    Re: MC5 Diary
    I am transcoding one by one (which is a pain for 140 4K files) but this is the only way to see what is bugging MC.
    I have some G7 files (8-10), mostly GH5 files which are: 1, 10 bit with all the others 8 bit and some of them are Slow motion clips, shot with variable framerate of GH5 at 1080p.
    I use only the Avid Generic Plugin but I will link to QT when some of the files isn't going through.
    I'll let you know.
    (P.S.>All of the aboved mentioned files are .mp4 (LPCM)).
    Desktop PC
  • Tue, Sep 5 2017 9:00 PM In reply to
    Re: MC5 Diary
    At this point, what we really need is someone with a GH5 do do a bunch of tests:
    In 8-bit (4:2:0) Link to short (5-minute or less) MP4 and QT files using Avid Generic and QT plug-ins.
    Transcode both using defaults.
    Transcode both using Set Framerate to Project.
    Link to long (20-minute or longer) MP4 and QT files using Avid Generic and QT plug-ins.
    In 10-bit (4:2:2) Repeat the same as for 8-bit
    The question is: What actually works (what links and plays back properly, and what transcodes properly)?
    I am on it David.
    Desktop PC
  • Tue, Sep 5 2017 9:21 PM In reply to
    • Vilem
    • Prague
    • Posts 1,427
    • Points 15,690
    Re: MC5 Diary
    According to my theory,
    the Generik plugin fails to transcode long shots (30+).
    It does not matter whether it's "mov" or "mp4".
    In some frame rates, incorrectly interprets the length and TC.
    QuickTime plugin links and transcodes "mov" but out of 10bit codec. Qt does not link "mp4" files.
    Material GH5 Firmware 1.1.
    V.
  • Wed, Sep 6 2017 1:37 AM In reply to
    Re: MC5 Diary
    While I was shooting the GH5 files we need to test out, I transcoded my 140 files 4K GH5 files at XAVC 4K Intra CBG Class 300 (by 10) using Avid Generic Plugin without a single failed transcode.
    All at convert at project's framerate.
    And I am converting another 25 (GH5) files with the same settings.
    Then I'll start testing the GH5 files David asked.
    Desktop PC
  • Wed, Sep 6 2017 3:19 AM In reply to
    All files are linked fine and playback fine.
    Of course with some delay as we are talking about 1 hour and 47 4K AMA linked files.
    Desktop PC
  • Wed, Sep 6 2017 3:26 AM In reply to
    GH5 4K 25p mov 8bit 5 min transcode to DNxHR SQ as keep source frame rate by Avid Generic plugin:
    Failed by error (not pipe etc. but another one).
    Desktop PC
  • Wed, Sep 6 2017 3:41 AM In reply to
    GH5 4K 25p mov 8bit 5 min transcode to XAVC 4K Intra CBG Class 300 as conver to project frame rate by Avid Generic plugin:
    Completed.
    (the funny thing is that in this case the Avid Generic Plugin works with XAVC resolution but not Avid's.)
    Desktop PC
  • Wed, Sep 6 2017 3:58 AM In reply to
    GH5 4K 25p mov 10bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate by Avid Generic plugin:
    Failed by same error
    (Exception: NEMFileWriter::ExecuteInternal TIMEOUT - NEMFileWriter has detected upstream pipe stal...).
    Desktop PC
  • Wed, Sep 6 2017 4:40 AM In reply to
    GH5 4K 25p mp4 (lpcm) 8bit 5 min transcode to DNxHR SQ as keep source frame rate or to XAVC 4K Intra CBG Class 300 as convert to project frame rate by Avid Generic plugin:
    Completed.
    (The DNxHR SQ transcode was the fastest of all tests.)
    Desktop PC
