Latest post Thu, Apr 21 2011 3:17 PM by Prince Amevor. 309 replies.
Page 20 of 21 (310 items) « First ... < Previous 17 18 19 20 21 Next >
  • Thu, Oct 21 2010 6:35 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Re: MXO2 Mini and HD monitoring: is it all necessary?
    Wayne A:
    A stand alone capture app, which will allow users with fast enough CPU's to encode to installed codec's on thier system, and use AMA to bring the file into Avid Media Composer
    and if you wonder how fast system that is needed, I can tell that my little MBP does this brilliant even with DNxHD 185X captured to a usb drive, no dropped frames at all, something really worth to wait for for all of you
    Tomas
  • Tue, Oct 26 2010 2:05 PM In reply to
    mjolnarn:
    Daniel:
    what i am missing?
    You aren´t missing anything Daniel, you can do all that described capturing, but not with Media Composer, you have to use the apps brought with the unit or another capturing app to be able to capture
    One feature would be the device's ability to upscale/downscale projects to fit the specifications of the monitor you are monitoring with.
    I could be working on a 1080 project and view it on my consumer brand composite monitor. I just set my output to display SD letterbox and voila! Instant downscale.
    This feature is great when an editor needs to do work on location and can't carry around a big HD screen along. Plus, with the MXo2 menu, I can change my component out to do composite and S-video (or output SD through component) while still keeping full res on HDMI.
  • Tue, Oct 26 2010 3:02 PM In reply to
    • Wayne A
    • Joined on Thu, May 6 2010
    • Posts 75
    • Points 1,170
    • Avid Partner
    Re: MXO2 mini 23.976 PSF Warning!!!!
    Bloersch:
    I'm using the Matrox MXO2 Mini with MC 5.0.3.1 and have a playback problem:
    When you hit stop, the picture/blue position bar jumps 1-2 frames ahead.
    I also don't see the full quality picture when I pause. Looks like only one field.
    Mojo SDI and FSP works better, is it a known issue?
    I'm using it in a 25p PAL project on CRT monitor (s-video), now.
    It works good with FCP so I guess it should be a driver/setting problem, not the hardware itself.
    Hello,
    The snap ahead at stop is a known limitation of the Avid software.
    Regards
    W@
  • Tue, Oct 26 2010 5:41 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    Wayne A:
    Never seen that on old Meridien, Adrenaline, Cujo/Mojo SDI and Classic/DX Nitris hardware, not to mention software only; perhaps You mean that's a known limitation of MC on MXO2?
    Symphony 20.06, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Tue, Oct 26 2010 6:26 PM In reply to
    • Wayne A
    • Posts 75
    • Points 1,170
    • Avid Partner
    luca.mg:
    Wayne A:
    Hi Luca,
    On Adrenaline, users have experienced a snap back in the past. For the others, I'm not 100% sure, but I do know that with the Mini this is aknown limitation of the Avid software, and not the hardware itself.
    Regards
    W@
  • Tue, Oct 26 2010 7:14 PM In reply to
    I'm not convinced either that this is in the Avid software. Adrenalines had snap back, but I'm fairly sure that the FW pipe was to blame for that.
    But even more so, I did not experience that issue at all over the past two weeks, working on an MBP with MXO2 Mini, but I must admit that I was in 23.976p/1080, output set to 29i/1080, with an HDTV as monitor, connected via analog component.
  • Tue, Oct 26 2010 7:55 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    To be honest, there's been an annoying MC version with inaccurate stop, but that was fixed pretty soon, or perhaps the increasing hardware power took care of that, so, all in all, I would not say that snap back, or forward, is an Avid pecularity.
    peace luca
  • Thu, Oct 28 2010 12:24 PM In reply to
    • sven2615
    • Joined on Wed, Apr 12 2006
    • Berlin
    • Posts 152
    • Points 2,030
    Wayne A:
    sven2615:
    any good news concerning 24p playback with the matrox mxo2 mini?
    just sold my SDI compatible client monitor and the next feature film is starting in january ...
    thanks for feedback.
    cheers
    sven
    Hi Sven,
    True 1080p 24 (not to be consued with 23.98 which is already supported today) has made it into our 2.1 release for the Mac. However, I am still working with Avid to bring support to Media Composer 5. So it is there, but Avid will need to support it before you can use the new frame rates, and true P output of your mini's on the Mac
    What's new in 2.1
    True 1080p 24 and 30 (not to be confused with 29.97 which is already supported today)
    The ability to select the HDMI output to be PsF or P for 1080p (requires support from Avid)
    and there is more new features to be provided in the 2.1 Mac release from Matrox
    W@
    thanks for your feedback wayne
    i really appreciate that you take care of our needs. looking forward 2.1 ...
    Keep it up!
    cheers sven
    Avid Media Composer 7.0.3 | MacPro 3.5 GHz 6core 32GB RAM | AJA T-Tap |||| The Audio Mixer is too BIG since mc6!!! [view my complete system specs]
    www.svenbudelmann.com
    http://www.imdb.com/name/nm0118967/
  • Sun, Nov 7 2010 3:24 PM In reply to
    • jok71
    • Joined on Mon, Oct 29 2007
    • Posts 39
    • Points 505
    Wayne A:
    Never mind who is to blame; is anyone at Avid or Matrox actually working to resolve this issue? I would love to equip all my Avids with Matrox boxes, but I won't do so until this issue is solved.
    MC 2019.12 - Windows 10 Professional - HP Z4 - Quadro P2000 - 32GB RAM - Intensity Pro 4K [view my complete system specs]
  • Sun, Nov 7 2010 4:25 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    jok71:
    Wayne A:
    yes, an absolutely total disaster, there are a solution however
    Mojo DX
    If that isn´t good enough, there are of course other alternatives
    Nitris
    It´s all about the pricetag of course ..
    Tomas
  • Wed, Feb 23 2011 6:22 PM In reply to
    • sven2615
    • Berlin
    • Posts 152
    • Points 2,030
    KNOCK KNOCK,
    again me. any news??
    i installed the 2.1 driver, but 24p projects still doesn´t work in media composer 5.0.3.7.r
    cheers
    sven2615:
    Wayne A:
    sven2615:
    cheers
    sven
    Hi Sven,
    What's new in 2.1
    W@
    Keep it up!
    cheers sven
  • Wed, Feb 23 2011 8:57 PM In reply to
    • Wayne A
    • Posts 75
    • Points 1,170
    • Avid Partner
    Hi Sven
    Avid last week had the following announcement in regards to MC 5.5
    "New format support with Matrox MX02 Mini now includes SD 23.976, 720p 23.98, 1080p 23.98, 1080p 24, 1080p 25, and 1080p 29.97 as well as the ability to select PsF or true P output in 1080p modes. Also MX02 Mini with Max acceleration has been qualified on Mac OS systems."
    You can see the entire list here;
    http://www.avid.com/US/products/Media-Composer/features
    And the updated Matrox/Avid FAQ's here;
    http://avid.force.com/pkb/LegacySearch?DocId=366347
    Regards
    W@
  • Thu, Feb 24 2011 5:05 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    G'day Wayne, does this mean still no support for PAL SD 24p?
    peace luca
  • Mon, Feb 28 2011 2:48 PM In reply to
    • Wayne A
    • Posts 75
    • Points 1,170
    • Avid Partner
    luca.mg:
    Hi, 23.976 is supported by Avid in NTSC
    You can see what Avid supports in mouch more detail here;
    http://cdn.pinnaclesys.com/SupportFiles/attach/HW-Capabilities_1.2.pdf
    Regards
    W@
  • Mon, Feb 28 2011 2:53 PM In reply to
    Wayne A:
    Still a pity that 24p PAL is overlooked. Not for the first time.
