Latest post Wed, Jan 13 2010 5:18 AM by Igor Ridanovic. 3 replies.
  • Thu, Jan 7 2010 1:06 AM
    • cable
    • Joined on Sun, May 27 2007
    • Pacific NW
    • Posts 401
    • Points 5,170
    metadata
    I'd like to add my own custom metadata to the mxf's that MetaFuze creates but I can't seem to find a way to do this. There must be a way. Anyone know how to do this?  An example would be to add a unique column such as Animator so I know who animated what shots.  I've tried just adding this data to the batch xml after <comment></comment> but the batch fails with this new info. I added <Animator>John Doe</Animator> hoping this would work.
    Any ideas?
    Thanks.
    -cablet
    8 x Media Composer 2020 HP Z4 64GB RAM AJA and Blackmagic Avid Nexis Pro [view my complete system specs]
  • Thu, Jan 7 2010 1:15 AM In reply to
    Re: metadata
    MetaSync may do what you want.  It gets installed along with Avid Media Composer.  There are also white papers in the Knowledge Base.
    (wwld)
  • Sat, Jan 9 2010 11:44 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
    • ! Avid Employee
      Avid Certified Instructors - Video
      Moderator: Film and 24p
    Re: metadata
    You can always add it to the ALE which carries more metadata as well as custom fields. This file can be merged into existing clips or imported directly first and then a relink function done.
    Michael
    24p.com
  • Wed, Jan 13 2010 5:18 AM In reply to
    Re: metadata
    Also, if you're using the ALE method to bring clips to Media Composer you could edit the ALE directly or write a script to automate the process.
    Igor Ridanovic
    www.HDhead.com
