Latest post Sat, Oct 10 2009 9:49 AM by mjolnarn. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Fri, Sep 25 2009 9:55 AM
    TOD and AVCHD Files
    Do any versions of Avid Media Composer import .TOD files or AVCHD, or do they have to be converted into another format for use in AM?
  • Sat, Sep 26 2009 8:47 AM In reply to
    Re: TOD and AVCHD Files
    Would AMC 4 support mpeg2 or AVCHD?
  • Sun, Sep 27 2009 9:09 AM In reply to
  • Sun, Sep 27 2009 9:39 AM In reply to
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,680
    • Points 20,605
    • Moderator: MCA Mac
    I've not seen anything to suggest they are supported in the latest version. AVC-Intra support as been added, but that's as closes as it gets (which is not very close)
    Various systems - including HP Z440 and Z840 workstations Media Composer 2018 [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
  • Sun, Sep 27 2009 4:33 PM In reply to
    • sasha1
    • Posts 394
    • Points 5,265
    I use Premiere CS4 to convert AVCHD...
    Avid 1: HP Z420. Quadro 4000, Motu, MC 7.02. Avid 2: Dell T3400 - Core 2 Quad 2.83 - 8GB RAM - Quadro K2000 - Matrox Mini - MC 7.02 [view my complete system specs]
  • Sun, Sep 27 2009 9:46 PM In reply to
    So would I be better off skipping the middle man and just using Premiere Pro CS4 if Avid is not advanced enough to support many formats? I am not making academy award winning pictures Smile
  • Sun, Sep 27 2009 9:51 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,821
    • Points 63,225
    Based on your question, I would try Premiere CS4 for a month or so and then tell us what you think. If your main source of media is ACVHD then you may find CS4 to be better suited to your needs. I've just never found Premiere to be all that stable - but that's just me.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Sep 27 2009 10:03 PM In reply to
    BarkinMadd:
    Try both.  MC has a fully functional 30-day trial version.  See which one you like better.
    good luck,
    Carl
    Media Composer 2024.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 64gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Sun, Sep 27 2009 10:17 PM In reply to
    Yes, Premiere Pro CS4 has crashed on me a time or two. That is why I like MC, it just works. When I load large files in it they work, they do not crash the MC. I have tried Sony Vegas and Premiere Pro and both crashed (though Vegas is much more stable, at least for me). It is just a pain to convert the files to work with MC and then wait much longer for it to convert them to something it can use. There are cheap programs that just start working with AVCHD, mpeg2, and others, but then you get to a file longer than a few minutes and they crash Smile I guess I am stuck with Avid until they become more advanced and support a wide range of file formats or Vegas or Premiere become stable. Thanks everyone for the help.
  • Mon, Sep 28 2009 12:50 AM In reply to
    • DylanReeve
    • Posts 1,680
    • Points 20,605
    Typically the fundamental difference between the way applications like Premiere and Vegas work with clips and the way Avid does is largely down to the file-handling. Premiere, Vegas and FCP all use direct file-system access to work with files in the native formats using various codecs, APIs and applications. This makes those apps more flexible in terms of what they support and how quickly, but tends to have a negative impact in real-time performance, interoperability and stability. And even with that approach new format support is hardly guaranteed (FCP still has major issues with AVCHD I understand).
    Avid's approach, with using Avid-written codecs, and managing the media directly usually provides a more stable experience and better performance, but does make working with non-native files formats more difficult. However Avid's new AMA somewhat bridges these concepts and may, in the future, be the means by which more varied format support can be offered. But at this stage it's a wait and see thing I guess.
  • Mon, Sep 28 2009 3:03 AM In reply to
    • Mark Renz
    • Joined on Tue, Feb 21 2006
    • Kansas City, MO
    • Posts 1,043
    • Points 13,070
    Use the Panasonic AVCHD to P2 converter. Then use a version of MC with AMA, you only wait for the conversion. With AMA there is instant access to the media. You will need to find version 1 if you use a non Panasonic camera. Later versions only convert from Panasonic AVCHD cameras. This is a free converter. I use this workflow all the time.
    Media Composer Nitris DX 2018.12.15 with Symphony option Win10 64Gb Ram * Media Composer 8.8 with Symphony option Nitris DX Dual 2.66GHz "Westmere"... [view my complete system specs]
  • Mon, Sep 28 2009 6:41 AM In reply to
    I tried the Panasonic AVCHD to P2 converter (actually found the link on Avid's site), but it was the version that only converts for Panasonic. Would anyone know where the earlier one could be found?
  • Mon, Sep 28 2009 7:39 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    wordoffaith:
    PM me your mail adress Smile
    Tomas
  • Mon, Sep 28 2009 11:18 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 948
    • Points 12,245
    I have two JVC camcorders (GY-HD200 and GZ-HD7). The HD7 writes TOD-files on the hard disk. TOD-files are MPEG-2 files. I use two methods to work with them. I use Avide Liquid Version 7.2, which can directly import TOD-files without any problem. If I edit with media Composer (my preferred method), I transcode the TOD-files with TMPGEnc 4.0 Xpress, which converts the TOD-files into DNxHD-enccoded files for fast import into Media Composer. TMPGEnc 4.0 Xpress can transcode nearly any format to any other format and the results have a high quality.
    Joachim
    Joachim Claus
  • Mon, Sep 28 2009 11:46 AM In reply to
    • gerbow
    • Joined on Wed, Oct 3 2007
    • Wales, UK
    • Posts 132
    • Points 1,745
    If you've got a really fast I7 then it may be worth looking at. But realtime performance if you plan on adding filters, titles or doing any color correction may still be an issue. AVCHD, whilst an excellent acquisition codec, is a heavily compressed long gop codec that requires serious cpu horsepower to decode on the fly. Use of an intermediate codec (which is how Apple approach avchd (not avc-I) with imovie (AIC) or FCP (Pro Res)).
    You could convert to DNxHD using one of the many available third party converters and fast import those files (although you will take a hit in terms of file size - each convereted intermediate file will be about 10 times the size of the original avchd file). If you check out the Premiere Pro CS4 forums you will find that some people are having success, but may others are having big issues. Additionally, be aware that apparently timecode is not available when using avchd in PPro CS4 (each clip starts from 00:00:00:00). Although if you use the panasonic avchd to DVCproHD converter you will retain and be able to use the timecode (there is a discussion on the premiere cs4 forums about this issue with a Panasonic HMC 150).
    Personally, I convert to DNxHD and get excellent realtime performance for 1080p.
    It is a pity that Avid don't have a version of FCP's log and transfer feature though (because that would simplify matters, especially if it would ingest in the background and allow you to carry on editing - which is what FCP does!).
    Apple Mac Pro 5,1 2.8GHz Nvidia Ati 5770 graphics card, 1TB system drive; 3 media drives set as raid 0. Mac OS 10.7.3 Black Magic Design Intensity Pro... [view my complete system specs]
