Latest post Tue, Jun 16 2009 12:27 AM by james4ihl. 3 replies.
  • Fri, Jun 12 2009 11:53 AM
    • james4ihl
    • UK
    • Posts 57
    • Points 725
    DVD Problem Xpress Pro Studio HD
    Sorry if this is the wrong forum but haven't posted in a while and it appears Xpress Pro forum is now archived? I believe this issue may not be specific to that software though.
    Having a weird problem exporting/creating a DVD. I'm exporting the timeline
    sequence as a QT reference file, then compressing to mpeg2 in sorenson squeeze
    and burning in Avid DVD.
    The issue is that the footage on the DVD appears to have jaggy edges and not
    quite the resolution I'd expect.
    I've spent quite a bit of time on this myself trying different export settings
    in the Avid (including an uncompressed export test) and also different settings
    in Sorenson Squeeze. None seem to solve the issue.
    On the QT ref. file, the titles at the start (which were imported as a
    progressive sequence) look fine, the live footage looks interlaced - but this
    may be normal when playing back through QT player?
    Is there anything obvious I might have overlooked that could be causing this?
    My only suspicion is that the first footage I had was shot 25p (this is on DV), so
    I set up a 25p (DV 25 420) project. It seems now as if some/all of the cameras
    on subsequent tapes were 25i. The titles/ident graphics, etc. were progressive.
    Could this mixing of 25p/i footage in a progressive project have an effect such
    as this?
    Original settings (as I recall them away from the Avid) were:
    Export:
    QT reference
    Same as source
    Video and Audio
    Color levels RGB
    720 x 576 size to fit
    Field order options are greyed out since it's a 25p project
    Pixel aspect ratio same as source (non-square)
    Sorenson Squeeze:
    Mpeg-2
    DVD PAL Large preset used
    No other filters, etc. applied
    Other info:
    Avid Xpress Pro 5.1.3
    QT 6.5.2
    Any ideas welcome as I have a client waiting. I've made them aware, but they
    still need a quality DVD asap.
    TIA
    James
    Xpress Studio HD Essentials HPxw8200 3.4GHz DP/ 2GB RAM Quadro FX-1400 2x500GB Internal HDD G-Raid 500GB external partitioned to 2x200GB and 1x100GB... [view my complete system specs]
  • Fri, Jun 12 2009 12:43 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    Re: DVD Problem Xpress Pro Studio HD
    Guessing here - Sorenson does not deinterlace your footage because it believes it's progressive so any interlace footage burried in your sequence is never deinterlaced (Avid doesn't deinterlace it). Take a sample of your 25i footage and deinterlace it (perhaps with Sorenson) and then inject it back into your original timeline and see if that corrects the problem.
    Also, view your results on an external DVD / TV system, not QT player, just to make sure the problem you're seeing isn't a QT player problem...
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Jun 12 2009 1:04 PM In reply to
    • TCediting
    • Joined on Wed, Jan 18 2006
    • Colchester, CT USA
    • Posts 30
    • Points 390
    Whenever I make a DVD, before expoerting from Avid I always do a video mixdown first then I export that.  In Sorenson I always add a filter to remove the deinterlace before compressing.  Trying one or both of these may help.
    MC 2.8.1; Studio Complete 5.7; analogue Mojo; Digi 002; XP Pro; Dual Xeon 3.2GHZ HT/800 FSB/550W; PS/7525 Chipset/8 port SATA; 2GB DDR RAM; System Drive... [view my complete system specs]
    MC 2.8; Studio Complete 5.7; Mojo; Digi 002; XP Pro; Dual Xeon 3.2GHZ HT/800 FSB/550W; PS/7525 Chipset/8 port SATA; 2GB DDR RAM; System Drive 200GB ATA100 7200 RPM 8MB Cache; spare drive 200GB ATA100 7200 RPM 8MB Cache; Serial ATA drives (2) 200GB SATA 7200 RPM 8MB Cache;(2) External SCSI 146GB drives; Quadro FX1400 PCI-e128MB dual monitor DVI; (2) Samsung 711T 17" LCD w/DVI-I; Sony DRU710A DL DVD-R/-RW/+R/+RW; Sony DSR-25; Sony PDW-U1 Optical Drive.
  • Tue, Jun 16 2009 12:27 AM In reply to
    • james4ihl
    • UK
    • Posts 57
    • Points 725
    Thanks guys will give those suggestions a try. Sorry for delayed reply, was away over the weekend.
    Best wishes,
    James
