Latest post Tue, Jun 9 2009 3:42 PM by Haze. 42 replies.
Page 1 of 3 (43 items) 1 2 3 Next >
  • Sat, Jun 6 2009 2:56 PM
    Why Does MC Keep Old Precomputes After Exiting?
    I can understand keeping previous precomputes during an editing session for Undo. But upon exiting, why doesn't MC cleanup old effects precomputes?
    I know the Media Tool will show some imported graphics as precomputes, and you don't want these to be deleted. But the system clearly knows which old precomputes are related to effects. Certainly these could be safely removed upon exiting?
    Or am I missing something here? ... wouldn't be the first time, LOL.
  • Sat, Jun 6 2009 3:00 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 950
    • Points 11,625
    Re: Why Does MC Keep Old Precomputes After Exiting?
    This would be a great feature - especially in audiosuite where you have to render and tweak, render and tweak . .
    1 MC4 Nitris DX on 12 core 2.66 mac pro 6 Gigs of Ram, 2 Symphony Nitris DX on eight core mac pro with 12 gig ram, 3 MC7 on Mac Pro, IMAC, and Macbook... [view my complete system specs]
    WWLD?
  • Sat, Jun 6 2009 3:04 PM In reply to
    You can clean renders in out and then render new effects.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Sat, Jun 6 2009 3:13 PM In reply to
    sverkalo:
    Do you mean the "Clip -> Clear Renders..." function? Wouldn't this make it even worse having to render everything again and creating new (duplicated) precomputes?
    When exiting bigger projects I have seen a desciption field saying "Cleaning Database". So I thought MC would 'forget' and delete unneeded precomputes. Am I wrong? If so, this is definitely worth a feature request!
    my $0.2, g_f
    Dell Precision m6400, Intel QX9300 2,5GHz Quadcore, nVidia QuadroFX 3700@1GB, 4GB RAM, M-Box2, MC 3.5.1 Software Only, ProTools LE 8cs2, WindowsXP 32bit... [view my complete system specs]
  • Sat, Jun 6 2009 3:26 PM In reply to
    I believe that old precomputes of effects that have since been rendered again just hang around.
    I tested this by opening the Media Tool and listing precomputes. It showed eight precomputes for an effect. I tweaked the effect, re-rendered it, and low and behold, there were now nine precomputes for the effect. I exited MC and re-opened it, and the nine precomputes were still there.
    Again, perhaps I'm missing something, or my methodology for checking how old precomputes are handled is flawed?
  • Sat, Jun 6 2009 3:33 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    You can use the 'select unreferenced media' using the media tool - just make note that it only selects unreferenced based on open bins. There's also a select unrendered titles...
    Not sure if this will help and sometimes it does remove things I was hoping to keep...
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Jun 6 2009 3:55 PM In reply to
    Thanks. I do know how to delete them. What I don't know is why are they there.
    What purpose could they possibly serve once I've closed a project and chosen to exit MC?
  • Sat, Jun 6 2009 4:37 PM In reply to
    Bobby:
    You could put your sequence in it's own bin and then in "set bin display", uncheck everything except "show rendered effects". You could then delete those files and re-render your timeline. You would then only have those re-renders on the system.
  • Sat, Jun 6 2009 6:47 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    BobbyMurcerFan:
    I don't understand your question then. How is MC supposed to know you don't want the precomputes - they're rendered effects, etc. that you will most likely want the next time you view a timeline. The best MC can do is to determine which precomputes are no longer referenced by any clip across all projects - rather than making this automatic (which is dangerous, I suppose) they provide you with the tools to manage this yourself (admittedly, the tools could be better).
    Steve
  • Sat, Jun 6 2009 7:00 PM In reply to
    Steve, I believe he is talking about the superceded pre-computes of rendered effects that are left over each time you tweak a particular effect, audio or video, and re-render it. All of those superceded renders stay on the system until you run the media tool and delete them, along with master clips and media files.
  • Sat, Jun 6 2009 7:54 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    I see. Avid's documentation explains that they leave these so that you can undo your changes and revert to the previous rendereed effect. As I mentioned, they could automatically remove these once you exit MC (since clearly they are no longer referenced) but perhaps Avid felt that this would be too dangerous?
    Steve
  • Sat, Jun 6 2009 8:06 PM In reply to
    Given 32 levels of undo, I believe you're right. And now with drive space limitations becoming less and less of an issue as time goes on, it doesn't seem to be a big problem for most people, so perhaps that's why Avid leaves it alone. It's the approach of "it's better to have it and not need it, than to need it and not have it."
  • Sat, Jun 6 2009 8:15 PM In reply to
    "... than to need it and not have it ..."
    But, as mentioned above, once the session has ended by exiting MC, they are no longer part of an Undo List.  They are just taking up space.
    (wwld)
  • Sat, Jun 6 2009 8:21 PM In reply to
    Randall L Rike:
    Agreed, so an option "delete superceded renders?" on exit would be in order. The user decides.
  • Sat, Jun 6 2009 8:42 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 950
    • Points 11,625
    Larry Rubin:
    Exactly. I hope someone from Avid sees this, since it's not on the feature request forum.
    WWLD?
