Latest post Mon, Jun 8 2009 3:46 PM by TCurren. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Jun 5 2009 7:41 PM
    • lewison
    • Joined on Thu, Jul 3 2008
    • Posts 5
    • Points 85
    Will Avid support a MC 3.5.1 workstation if I upgrade to Vista 64 sp2?
    I have no problem with updating to sp2 and I think I have a couple of good reasons.
    I'm wondering if Avid support will not support my systems if I upgrade the O/S.
    What think you?
    5 HP xw8600 - Vista Business 64 sp.1 - Media Composer 3.5.1 - Unity.
  • Fri, Jun 5 2009 10:38 PM In reply to
    • Posts 11,384
    • Points 233,280
    Re: Will Avid support a MC 3.5.1 workstation if I upgrade to Vista 64 sp2?
    They will most likely tell you to g back to SP1 since SP2 in this config. hasnt been officially recommended.
    I have no idea how it will behave but if you have issues - they will ask you your config and this isnt supported yet.
  • Sat, Jun 6 2009 2:00 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    This type of question comes up quite often and I'm curious - what do you mean 'Will Avid support my system...?"?
    Do you contact Avid on a regular basis to ask for support? Are you concerned that if you run into a problem using MC and then call through to Avid support that they will turn you away because you're running SP2 of Vista? (as Marianna says, they probably will tell you to downgrade to SP1, but I would hope that if the defect you report is a known issue with 3.5.1 that Avid support would let you know).
    I'm not trying to be 'smart' here - I'm curious because I've never ever contacted Avid for any issue (because this forum is so darn effective) so if your question is 'Will MC 3.5.1 work under Vista 64 SP2?" the answer is YES (software only), for some, but because there are so many variables to any computer system, the answer may be NO for others and that's just the way things are. Because Avid doesn't officially support SP2 you're not going to get the answer you may be looking for.
    The other consideration is that SP2 has some known issues with sound cards (and a few other issues) so if you're determined to move to SP2 I would highly recommend that you use a product like Acronis True Image to ghost your system disk before the SP2 update so that you can quickly roll-back to your pre SP2 configuration if you find that SP2 causes you issues.
    Good luck,
    Steve
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Jun 8 2009 2:49 PM In reply to
    • lewison
    • Posts 5
    • Points 85
    We have well over a dozen Media Composer installations and purchase a support contract  for most of them.  I usually end up calling them on average once a month.  They are extremely helpful on many issues.
    There definitely are some things that Avid will stop supporting.   There have been instances where I got the wrong driver installed or setting that is wrong and certainly they will point that out and help me correct the problem.
    Almost everytime I contact them, they ask what operating system we are running.  I would suspect if I told them that I was running SP2.   They would stop support until I returned the O/S to the "certified" version.  Since, we rely very heavily on these systems there is no way I could restore the image back and forth everytime I had a software issue with Avid.
  • Mon, Jun 8 2009 3:04 PM In reply to
    • lewison
    • Posts 5
    • Points 85
    I realize that I've kind of answered my own question, but I just wonder i anybody has heard if Avid is going to be quick to support SP2 or if they've already had experience with Avid Support and SP2.
  • Mon, Jun 8 2009 3:46 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,995
    • Points 37,770
    BarkinMadd:
         This is always an excellent suggestion and you should be doing it at all times anyway in case a drive dies you can be up and running again in minutes.
    For what it's worth, when you buy Seagate or Maxtor drives, it comes with a free copy of rebranded Acronis True image for free. Save a few bucks right there....
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
