Latest post Mon, Jun 8 2009 11:40 PM by FunkyDragon. 42 replies.
Page 1 of 3 (43 items) 1 2 3 Next >
  • Fri, Jun 5 2009 12:24 AM
    • ianeditz
    • Joined on Thu, Jan 15 2009
    • Posts 48
    • Points 745
    Blacklisted Effects
    Hi Guys, just got back from the joint compositing commitee meeting in Stockport and thought I would give you a heads up of the results.
    This years prohibited effects are as follows
    Dips to black
    Timewarping of crane shots accompanied by "whooshing"
    Crash zooms as a transition
    Lens flares as a transition
    and inappropriate blur dissolves
    Also we have decided that this years flashback tone is Magenta.
    Obviously for non union editors and compositors this is just for guidance but the prohibition is binding for unionised members and the neccesary disciplinary action will be taken for those found violating this code of conduct.
    Regards
    Ian
  • Fri, Jun 5 2009 12:28 AM In reply to
    • DylanReeve
    • Auckland, New Zealand
    • Posts 1,680
    • Points 20,460
    • Moderator: MCA Mac
    Re: Blacklisted Effects
    Oh, well... That's going to have a pretty big impact on all the promos I've been onlining lately.
    Thankfully the flare-out/glow transition is still okay.
    Various systems - including HP Z440 and Z840 workstations Media Composer 2018 [view my complete system specs]
    Dylan Reeve - Edit Geek // Online/Offline Editor // Post Production Supervisor
  • Fri, Jun 5 2009 1:18 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    Sad
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Jun 5 2009 1:29 AM In reply to
    ianeditz:
    There goes just about every Discovery, History, and TLC show - I think even "Biggest Loser" utilized most of these techniques this past season.
    With regard to Timewarped crane/jib shots with a SFX applied, do they offer alternative suggestions?  Or should we just cut in the entire 3 min jib shot?
    Also, when is a blur dissolve deemed "inappropriate"?
  • Fri, Jun 5 2009 2:05 AM In reply to
    ianeditz:
    ...and the neccesary disciplinary action will be taken...
    "Take that young'en out to the woodshed and tan his behind REAL good!"
  • Fri, Jun 5 2009 2:17 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Posts 588
    • Points 7,005
    Oh darn, I missed the meeting! I was thinking of petitioning to reinstate clock-wipes.
    Are we still allowed to use a wavy-lines transition to get to our magenta flashback? Do you have the HSL specs for the particular shade of magenta?
    cheers
    Campbell
    8.5 on a mongrel PC, Win 7, QT7.5, Nvidia GTX 970, 16Gb RAM, SSD, NAS for raw media and a Macbook Pro [view my complete system specs]
  • Fri, Jun 5 2009 7:48 AM In reply to
    ianeditz:
    There goes just about every reality show.  They'll have to rely on the content now.
    Uh oh.
    adios,
    Carl
    Media Composer 2020.9 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Fri, Jun 5 2009 9:12 AM In reply to
    • monkeyberry
    • bushveld
    • Posts 612
    • Points 7,595
    right.... back to the "if you cant solve it, dissolve it"
    have many avids all different, so cant post all specs... will rather say as required. KEEP THE DONGLE [view my complete system specs]
  • Fri, Jun 5 2009 9:46 AM In reply to
    • ianeditz
    • Posts 48
    • Points 745
    Any shade of Magenta will do, we are not control freaks!
    Big Smile
    There was a consensus that 2009 should be a retro year so clock wipes would fit the brief, I am working on a modern twist to the DVE cube but failing that I might just go really retro and use cuts.
    Ian
  • Fri, Jun 5 2009 9:55 AM In reply to
    • DylanReeve
    • Posts 1,680
    • Points 20,460
    I'm happy to report that in the last month or so I've used no fewer than 4 clock-wipes. A few heart wipes, and a few coloured-border multibox wipes.
    If only I could easily make them all rotate and trail like in a good old GVG switcher.
    All of which went to air on national network television, BTW.
  • Fri, Jun 5 2009 10:32 AM In reply to
    • ianeditz
    • Posts 48
    • Points 745
    Stop, you are making me feel nostalgic for all those hours wasted in dark rooms building slabs with 2 channels of DVE and having to get the front back switching spot on to make the effect disguise the cut perfectly.
    I must admit I have been struggling for my"trademark" transition since dips to white were outlawed in 2005 and then its B****** offspring the Glow and whoosh was outlawed last year.
    I experimented with using a 3 frame text wipe to do the trick but maybe I should have thought longer and harder about my choice of text. If I did perhaps I would still have that staff position.
    Ian
  • Fri, Jun 5 2009 10:44 AM In reply to
    Hi Ian,
    ianeditz:
    This is embarassing, but what are "cuts"?  I looked through the whole effect palette and I couldn't find any "cuts" anywhere.
    thanks,
    Carl
  • Fri, Jun 5 2009 11:10 AM In reply to
    • ianeditz
    • Posts 48
    • Points 745
    Hapy to help, I am working on a video tutorial as I know that cuts are a tricky thing to get your head round especially for the new whippersnappers brought up on FCP.
    Park up between 2 segments on your timeline and then from the effects pallette drag and drop any transitional effect to the junction and then change the duration to 0 frames and voila you have a cut. If you set the duration to 1 frame you can get a cut reminiscent of a sticky tape steenbeck join. Experiment and be happy
    Ian
  • Fri, Jun 5 2009 11:19 AM In reply to
    Nice one!  If you don't mind, I'm going to do a little write up for the Tips & Tutorials section.
    adios,
    Carl
  • Fri, Jun 5 2009 11:27 AM In reply to
    • gumbycat99
    • Posts 588
    • Points 7,005
    ianeditz:
    I dont get it.
    Without a transition to link the two shots together how will the audience know they're related? And what sound effect would you put with a cut?
    You guys are so avant garde!
