Latest post Mon, Jun 8 2009 6:12 PM by gkb444. 4 replies.
  • Wed, Jun 3 2009 9:29 PM
    • gkb444
    • Joined on Tue, May 6 2008
    • Oklahoma City, Ok
    • Posts 10
    • Points 130
    Mixed framerate problem
    I have footage that was all shot on p2 cards with an HVX200 but some was shot 24p, some 24pn and some in an sd format resulting in 59.94i footage. I used raylight mxfx to convert the 24p to the 24pn (23.94) but I don't know what to do with the 59.94i footage to bring it into the same project. the audio was also all done in camera and I don't know if converting the footage will change it's synch. any advice would be great. the director wants a 24p project but a finished project is the most important factor. I also have dvfilm's dv filmmaker program but I don't know if that would work for what I need to do since the footage is p2. any help would be greatly appreciated.
    Geoffrey K Boyd
    Mainboard : Asus P5KC Chipset : Intel P31/P35 Processor : Intel Core 2 Quad Q9400 @ 2666 MHz Physical Memory : 4096 MB (2 x 2048 DDR2-SDRAM ) Video... [view my complete system specs]
    Geoffrey K Boyd
    Above The Bar Productions
    "That's part of your problem: you haven't seen enough movies. All of life's riddles are answered in the movies." - Steve Martin (Grand Canyon)
  • Thu, Jun 4 2009 10:16 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 948
    • Points 12,125
    Re: Mixed framerate problem
    Geoffrey,
    the easiest way is to cross-convert your different files into a common format (target format), and then import them into MC with the project setting meeting your target project. I usually use "TMPGEnc Xpress 4.0" from Pegasy Inc, see www.pegasys-inc.com It allows you to import files of different formats (1080i, 720P) and converts them to a destination format of your choice. For import into MC,I select DNxHD based Quicktime format of the desired framerate. Try it and you will love it.
    Joachim
    Joachim Claus
  • Thu, Jun 4 2009 11:48 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    Hi Joachim,
    When you convert from interlaced to a progressive format using TmpGEnc, do you setup the deinterlace filter with custom settings or do you use the default?
    Steve
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Jun 5 2009 11:27 AM In reply to
    • Joachim Claus
    • Posts 948
    • Points 12,125
    I use the default setting. I do this kind of transcoding very often (from 1080i/50 to 1280P/50) and never had any trouble or quality issues.
    Joachim
    Addition: I have recently discovered, that MC imports 1080/50i Quicktime files into a 720/50P project, and creates appropriate 720/50P MXF-files. I had transcoded JVC's MPEG-2 full Hd files from the little HD7 disk recorder (file format is "Tape on Disk", .TOD) into 1080/50i Quicktime files.
    Joachim Claus
  • Mon, Jun 8 2009 6:12 PM In reply to
    • gkb444
    • Oklahoma City, Ok
    • Posts 10
    • Points 130
    the project I have has the audio recorded in camera, will this be an issue when converting? do I just pull the mxf files from the p2 cards? what about the audio?
    Geoffrey K Boyd
