Latest post Fri, Aug 5 2022 6:38 PM by David Yardley. 8 replies.
Page 1 of 1 (9 items)
  • Wed, May 13 2009 6:59 PM
    • autolux
    • Joined on Tue, Jan 15 2008
    • Redwood City Ca
    • Posts 67
    • Points 995
    Making waveforms larger in the timeline
    Hey Guys and Gals,
         Im editing some sound that was recorded lower than usual.  As I'm trying to edit the VO, the waveform representation is really almost non existent, just 3 flat lines.  Is there a way to scale or expand the waveform in the sequence window to have a better representation.  In Sound Forge, its a simple zoom in.  Any ideas from some fellow avid peeps?
    AB
    later.
  • Wed, May 13 2009 7:05 PM In reply to
    Re: Making waveforms larger in the timeline
    Enlarge the track vertically. Not sure about DS, but in Media Composer, drag the bottom of the audio track selector down, or park on the track itself and CTRL + L will enlarge, CTRL + K will reduce.
  • Wed, May 13 2009 7:29 PM In reply to
    • GusC
    • Burbank, CA
    • Posts 531
    • Points 6,570
    In the File>User Preferences menu, go to the 'Level Meters' tab.
    Select "Scale Waveform Display to Peak Level'.
    That should do it.
  • Wed, May 13 2009 8:25 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
    • ! Avid Employee
    You can do the very same in DS.  Press the control (Ctrl) key and left click drag the audio track.  Ctrl+J reduces all tracks and Ctrl+L enlarges them.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
  • Wed, May 13 2009 10:16 PM In reply to
    • autolux
    • Redwood City Ca
    • Posts 67
    • Points 995
    thanks a ton guys....that really helped me blow through this edit!!!!!
    Much appreciated as always!
    later.
  • Wed, May 13 2009 10:19 PM In reply to
    You're quite welcome. We're always glad to help out.
  • Thu, May 14 2009 4:58 PM In reply to
    • lordoff2
    • Joined on Mon, Jun 9 2008
    • Sofia, Bulgaria
    • Posts 16
    • Points 200
    Hi! In DS you have a command: "Scale Waveform Display". You can add this to keyboard.
    It's the same action if you make changes in Preference tab / Audio.
    Personaly I add this shortcut on "Alt + W" Very usefull.
    In Avid MC is applicable "hidden"Wink shortcut (not exactly, just not so popular). Ctr + Alt + K (or L) affect only waveforms, not track height! I like use for tracks with segment, imported from CD audio for example.
    Avid DS Nitris v.10.1.1 / xw8400 / Unity 5 / DS RP station [view my complete system specs]
  • Tue, Jun 22 2021 9:52 AM In reply to
    • tjones
    • Joined on Wed, Sep 5 2018
    • Posts 12
    • Points 175
    Hi there,
    Been a while but I'm running into an issue where the ctrl+alt+L keys just start my track playing.
    Trying to do multicam edit and I can't see the audio waveform. I know I can make the track bigger but I would really like to just expand the waveform height with in the track.
    I don't mean raise the volume or zoom in on the track, I mean just widen the waveform within the audio track so it is more visible and easier to work with.
    Does anyone have any input as to why this hot key set would not work and how to activate it properly?
  • Fri, Aug 5 2022 6:38 PM In reply to
    Command+Alt+L (or K) works on a Mac (MC 2018.)
    Symphony 2018.12.13 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 2018.12.13 OS 10.13.4 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja I/O express, SNS SANmp... [view my complete system specs]
