Latest post Tue, May 5 2009 12:35 AM by BarkinMadd. 20 replies.
  • Sun, Apr 26 2009 4:00 PM
    Avid Codecs not working with Adobe Media Encoder
    Files exporting from MCA Nitris using an Avid codec (Avid DV, DNxHD) show only black video when opened in Adobe Media Encoder.  They work fine with Sorensen.  Is anyone sucessfully using Adobe ME with AVID codecs?
    Thierry.
    Media Composer Nitris DX 3.5 HP XW8600 workstation Windows Vista Pro [view my complete system specs]
  • Sun, Apr 26 2009 4:36 PM In reply to
    • Galo
    • Joined on Sat, Sep 15 2007
    • Posts 21
    • Points 235
    Re: Avid Codecs not working with Adobe Media Encoder
    Hi Thierry, I used sometime AME whith MC 3.0 generated Qick time ref without any problem. Check your Quick Time version maybe there is some conflict, the aproved for CS4 is 7.4.5, the same of MC 3.0 but different of the earlier MC versions.
    Galo
  • Sun, Apr 26 2009 5:13 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    Are you on CS3 or CS4 ?
    CS3 works very well using this workflow.
    Tomas
  • Sun, Apr 26 2009 6:15 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    CS4 and DNxHD don't seem to play well together.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sun, Apr 26 2009 6:25 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    BarkinMadd:
    That was what I have heard, thanks for confirming it
    Tomas
  • Sun, Apr 26 2009 6:56 PM In reply to
    I have had mixed results with CS4 from DNxHD Using AME inside Encore no good results. Stand alone better. There was a patch for AME within the last 3 or 4 weeks I have installed it but not tested it yet.
  • Sun, Apr 26 2009 7:36 PM In reply to
    mjolnarn:
    I am using CS4.
  • Sun, Apr 26 2009 7:42 PM In reply to
    Do you have the latest DNxHD codecs installed on the CPU you are using with CS4?
    My experience is with the codecs with 3.1.2 but I think 3.5.1 uses a newer codec pac.
  • Sun, Apr 26 2009 8:05 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Yes, 3,51 is using codec version 1,20 I think.
    I am using CS3 and it all works well as said, my way to it is through Soundbooth.
    Tomas
  • Mon, Apr 27 2009 2:10 AM In reply to
    AndrewAction:
    Yes, MCA Nitris 3.5.1.
    Thierry.
  • Mon, Apr 27 2009 3:52 AM In reply to
    FWIW  AME had no trouble with a 70 minute PAL  DNxHD 120 QT Ref to Blu Ray MPEG encode here that I tested overnight.
    I choose to use Sorenson for actual the job as it did a 2 pass VBR in just over half the time AME wanted to take for a single pass VBR encode.  Two hours forty six mins for a two pass encode of 70 minutes is reasonably impressive to someone like me who is not fond of Sorenson
  • Mon, Apr 27 2009 6:23 PM In reply to
    is that using MCA 3.5.1 and AME CS4?  I tried using AVID codecs on both of my MCA systems and AME does not see the video.
    Thierry.
  • Mon, Apr 27 2009 6:47 PM In reply to
    Thierry Humeau:
    No it was with MC 3.1.2 and AME CS4 with the latest patches.
  • Tue, Apr 28 2009 10:17 AM In reply to
    Ok, so that is probably the issue.  On top of this, I am also having a field rendering issue when compressing for MPEG-2 DVD in Sorensen.  Basically, regardless of my field interpolation setting in Sorensen (upper, lower or even progressive), the resulting DVD plays jittery on CRT displays.  That it when downconverting my HD timeline (XDCAM HD 1080 60i) using AVID's DV codec, lower field.  If I use the "DV Stream" export, everything looks good except for the brightness/contrast levels that I need to tweek using the "darken" filter in Sorensen.
    I am really looking in the near future for an idiot proof feature to export MPEG-2 files for DVD or Blu-Ray output straight out of the AVID timeline.  That process is still way too complicated.
    Thierry.
  • Tue, Apr 28 2009 10:32 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Thierry Humeau:
    I have used the media encoder from CS3 for this for a couple of years, seems like an update to CS4 not is going to happen for a long time and my workflow is really working well, just a few glitches during the years that have been user related, one of them was with animated buttons on a dvd disc that played very choppy from the clients player, my dvd file was 2 pass encoded 6,5 - 7,2 and I just couldn´t understand why the clients player had problem with that file but the the probs was only when playing the menu so it didn´t seem to be the file.
    What I hadn´t thought about was that Sonic Dvd is encoding the animated buttons itself and that the default settings was set to 8 mbps, lowering those to 7 mbps made even the menu to play beatifully on the clients old dvd player.
    Tomas
