Latest post Sun, Mar 29 2009 9:44 PM by feglo. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Feb 20 2009 3:52 PM
    • Lennie
    • Joined on Fri, Mar 3 2006
    • Posts 12
    • Points 150
    OHCI Port not available
    I've recently upgraded from Xpress Pro to MC 3.1.2.
    With Xpress, I never had a problem digitizing DV from a Sony PD-150 connected to the front firewire port of a Mac Pro.  Today, I connected the camera to the system for the first time since my upgrade.  I went into deck configuration and tried adding the channel, but for port, I do not have the "OHCI" option.  All I have is "no port".  I've tried restarting the software with the cam connected, restarting the computer, trashed MCstate all to no avail.
    The Mac sees the camera in the system profiler and for a test to make sure, I can control and capture from iMovie.
    For the time being, I'm going to capture on my other system, but i'd like to get this working so I don't have this problem in the future.
    Any help is appreciated.
  • Fri, Feb 20 2009 6:02 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: OHCI Port not available
    Try opening a new user. Create a brand new channel in the deck config setings and see if the system sees the OHCI port now.
  • Tue, Mar 17 2009 6:23 PM In reply to
    • Lennie
    • Posts 12
    • Points 150
    Tried making a new user.  Same issue.
  • Tue, Mar 17 2009 6:35 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Wow, that took a long time! Where ya been? Wink
    Ok, so what Mac hardware do you have? Do you have anything other than the camera plugged into the CPU?
  • Tue, Mar 17 2009 6:58 PM In reply to
    • Lennie
    • Posts 12
    • Points 150
    I have a Mac Pro and the only thing plugged into the computer besides the camera is an external firewire drive, but it is plugged into a separate firewire/USB card
  • Tue, Mar 17 2009 7:05 PM In reply to
    • Lennie
    • Posts 12
    • Points 150
    Sorry forgot to add OS is 10.5.6
  • Tue, Mar 17 2009 7:08 PM In reply to
    For MC version 3.1.2 you should be running OS 10.5.5.
  • Tue, Mar 17 2009 7:39 PM In reply to
    • Lennie
    • Posts 12
    • Points 150
    I don;t think this is an issue because if I plug the camera into my Macbook Pro, os 10.5.6 and MC 3.1.2, the ohci port works correctly.
  • Tue, Mar 17 2009 7:50 PM In reply to
    • Lennie
    • Posts 12
    • Points 150
  • Thu, Mar 19 2009 1:37 PM In reply to
    • Lennie
    • Posts 12
    • Points 150
    I cannot believe I am the only one having this issue.
  • Sun, Mar 29 2009 9:44 PM In reply to
    • feglo
    • Joined on Sun, Mar 29 2009
    • Arkansas
    • Posts 24
    • Points 305
    I am having the same issue just with 3.5 on a  pc.
    Media Composer 3.5 Vista Business 64Bit Intel Dual Quad Core Q9650 3GHz Intel® Extreme Mother Board DP45SG 8GB Crucial Memory Nvidia Quadro FX1700... [view my complete system specs]
