Latest post Wed, Jan 28 2009 9:44 PM by malkotrez. 4 replies.
  • Wed, Jan 28 2009 8:45 PM
    • malkotrez
    • Joined on Wed, Jan 28 2009
    • Posts 10
    • Points 140
    Exporting 1080i/60 to Quick Time
    What are the best Export Settings and what is the best compressor and compressor settings to export 1080i/60 material to a Quick Time Movie that will eventually end up on DVD?
    Avid Media Composer MAC v3.0 - Mac OSX v10.5.6 - Dual 2.5 GHz PowerPC G5 - 8 GB DDR SDRAM - Sony HDR-FX1 - NVIDIA GeForce 6800 Ultra DDL: - Built In Sound... [view my complete system specs]
  • Wed, Jan 28 2009 9:13 PM In reply to
    Re: Exporting 1080i/60 to Quick Time
    What is your deliverable, just standard def dvd? Probably a quicktime ref movie.
  • Wed, Jan 28 2009 9:15 PM In reply to
    • malkotrez
    • Posts 10
    • Points 140
    Would that work for internet streaming also?
  • Wed, Jan 28 2009 9:19 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,739
    • Points 227,800
    • ! Avid Employee
      Moderator: MCA Mac
    In both instances you would need to first output a standard definition QT file. To do that, you need to switch your Avid project type to 30i in the format tab of your project window and then export the sequence to a QT file.
    DVDs will require you to encode the QT to an MPEG2 file in either the DVD authoring app or an encoder of your choice. As for the webe, there are many, many choices so checking with your ISP or the Site itself for their requirements is important.
  • Wed, Jan 28 2009 9:44 PM In reply to
    • malkotrez
    • Posts 10
    • Points 140
    In the manual is says you can cross-convert 1080i/60 to 720p/59.94. Is this not possible? In the format section I can change my -Project Type- to 720p/29.94 and 30i. But when I have the project type in 720p/29.94 my choice for -Raster Type- is -Standard- or -HDV-. Which settings should I choose or could I choose before export?
