Latest post Thu, Feb 12 2009 10:54 AM by pro---studio. 13 replies.
Page 1 of 1 (14 items)
  • Sat, Jan 24 2009 4:13 PM
    • pro---studio
    • Cologne / Germany
    • Posts 134
    • Points 2,115
    URGEND HELP NEEDED!! - Can't capture HDV on MC3.1.2
    I have a BIG Problem:
    I cannot capture HDV into my MC 3.1.2. I tried everything with reinstall, plug on and of the camera using different deck configuration settings - nothing worked. Avid won't even see my camera-
    Here are the Specs:
    Intel Quad Core
    Asus P5Q3
    4 GB Memory
    250GB HD
    Windows Vista 32
    MC 3.1.2
    Camera: Sony HC1
    I can see the camera in the device manager and use the camera for capturing in Prmiere Pro without any problems. Only Avid does not see the HDV device. If I switch the camera to DV output avid sees it - but not in HDV mode.
    I have a project that needs do be finished on monday - I'm really nervous now!
    Anyone with a solution?
    Thank you
    Andrew
    ASUS P5Q3 / Intel Quad Core 9650 / nvidia Quadro 4500 / 8GB Ram OCZ / onboard sound / 250GB SATA System HD / 1,5TB Video HD Raid5 on Highpoint 2310 / Mojo... [view my complete system specs]
  • Sat, Jan 24 2009 4:19 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    Re: URGEND HELP NEEDED!! - Can't capture HDV on MC3.1.2
    Perhaps as a stop gap, capture in Premiere and import into MC?
    Not all that helpful, but it could get you going for Monday.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Jan 24 2009 4:26 PM In reply to
    • pro---studio
    • Cologne / Germany
    • Posts 134
    • Points 2,115
    Yes - thank you - I'm doing that right now. But that can't be the final solution.
  • Sat, Jan 24 2009 6:23 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Try this.
    Close your avid and camera
    START
    RUN
    type: regsvr32 DVBuffers.ax
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Sun, Jan 25 2009 7:55 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    pro---studio:
    Camera: Sony HC1
    There is a preset for the HC1, have you tried that one.
    In your project settings for hd, be sure that hdv is choosen and not standard
    Tomas
  • Sun, Jan 25 2009 4:44 PM In reply to
    • pro---studio
    • Cologne / Germany
    • Posts 134
    • Points 2,115
    I did that - in fact that was the first I did!
    Avid does not see the HC1 if it is in HDV Mode no matter if the project is set to 1080i (HDV) or 25i (SD).
    This seems to be a bug, as the camera is recognised without problems if it is in DV mode.
  • Sun, Jan 25 2009 5:20 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    pro---studio:
    I think that a bug is something that is able to reproduce on other systems, I am using exactly the same cam and I am not able to reproduce it, sorry.
    Settings in the cam:
    Rec format 1080 i    ;  VCR HDV/DV  set to HDV  not auto   ;  I-link conv  OFF
    In Vista the cam is recognized in the windows device manager as Sony HDR-HC1E .
    With the cam still turned on I open up Avid , project settings 1080i/50 and raster HDV.
    I go to capture mode and choose the preset for the cam and all works well here, I am not able to reproduce what you are seeing
    Tomas
  • Sun, Jan 25 2009 5:30 PM In reply to
    Have you checked this Knowledge Base article? It may only apply to specific versions of the software, but it might also apply to your situation.
    Hope it helps.
  • Wed, Feb 11 2009 12:18 PM In reply to
    • pro---studio
    • Cologne / Germany
    • Posts 134
    • Points 2,115
    I tried this but the file gave me an error:
    You do not have a versionof Avid that is compatible with this file.
    I still cannot capture HDV through firewire. All other applications (i.e. Premiere Pro) can without problems. Only Avid doesn't recognise the camera.
  • Wed, Feb 11 2009 1:48 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    pro---studio:
    Do you have your mojo disconnected
    Tomas
  • Wed, Feb 11 2009 7:17 PM In reply to
    • pro---studio
    • Cologne / Germany
    • Posts 134
    • Points 2,115
    No but I run MC in Firewire mode not in DNA mode.
    I tired to disconnect - no luck.
  • Wed, Feb 11 2009 10:05 PM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 193
    • Points 2,320
    Try a different Firewire input. I had similar problems and a simple pcmcia/pc card firewire interface for 10 € fixed it. The onboard Asus Firewire input was the problem (dv was fine but hvx hd inputmode wasn´t recogniced).
    good luck.
    andre.
    MAC OS X 10.11.6 AVID MC 2018.3 + Avid Mbox Pro 3 MACBOOKPRO 15" Retina, i7 2.66 GHz Quadcore, 16GB Ram Dell UltraSharp U2711 Sony FS5 & Alpha... [view my complete system specs]
    Honestly I hate editing.
  • Thu, Feb 12 2009 2:56 AM In reply to
    • jackpro
    • Auckland NZ
    • Posts 59
    • Points 715
    Is the video and audio enabled in the capture mode?
    Intel Quad Q6600 Gigabyte GA-965P-DQ6 Nvidia 8800GTX 4x2GB DDR2 Ram 200GB, 320GB, 500GB, DVDRW Pioneer 112D Creative Xmod USB 22in CRT 19in LCD... [view my complete system specs]
  • Thu, Feb 12 2009 10:54 AM In reply to
    • pro---studio
    • Cologne / Germany
    • Posts 134
    • Points 2,115
    jackpro:
    Yes - it is really not the problem that I don't know how to use MC. The problem is related to another thread:
    http://community.avid.com/forums/t/62344.aspx
    Avid knows about that issue - but until today there is no solution to the problem.
