Latest post Wed, Dec 3 2008 4:47 PM by MisterDerp. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Dec 3 2008 7:39 AM
    • MisterDerp
    • Joined on Mon, Jul 7 2008
    • Toronto
    • Posts 8
    • Points 140
    Someone with Avid on Vista...A Quick Question
    I'm running Media Composer in XP and I'm a ton of touble using dual monitor.  I have a big widescreen paired with a small 4:3 monitor and the resolution difference makes it impossible for me to run the avid 'window' over the two screens.
    I also use Avid on my mac and I like the ability to drag my bins to the 2nd display, since there isn't a master 'window' which contains all the others.
    My question is...Can I do this with MC in Vista?  I.e. Do all the program's elements have to fall within the one main 'window' or is this just a limitation in XP?
    MC 3.0 w/SDI Mojo, C2D E6600 2.4ghz, 4gb 667mhz DDR2 Ram (OCZ), 512mb BFG 8800GT OC, 2 x 500gb Seagate Barracuda 7200rpm sata, Intel D975XBX2 Mobo, 550w... [view my complete system specs]
  • Wed, Dec 3 2008 10:38 AM In reply to
    • adamsonn
    • South Africa
    • Posts 695
    • Points 10,330
    Re: Someone with Avid on Vista...A Quick Question
    If you set both your monitors to the same resolution  then you can run a dual screen set up quite nicely.
    I have done this (1280x1024 for both resolutions) - for 4:3 editing (SD) you need to put your source and record viewers in the 4.3 screen to avoid the fat flat look of the 16:9 aspect ratio monitor, but it gives you plenty room for bin placement in the 22" monitor.
    MC6 machine: Intel Core i7 Asus P8-H67 64 bit Motherboard 1*1Tb SATA drive - partitioned to C (OS and programs) and D (data) drive 1*1TB SATA drive... [view my complete system specs]
  • Wed, Dec 3 2008 11:18 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    MisterDerp - Unfortunately, it appears that all subwindows of MC must exist within the main window of MC and hence you won't be able to accomplish what you were hoping for even under Vista.
    Avid could learn a thing or two from Adobe in this regard.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Dec 3 2008 2:17 PM In reply to
    • MisterDerp
    • Toronto
    • Posts 8
    • Points 140
    Ah....That's too bad.
    Guess I'll just have to get a bigger 2nd monitor at some point. (Can't set them to the same resolution...one is 1280x1024 and the other is 1920x1200.  Doesn't quite match up and the windows go all screwy)
    Thanks tho
  • Wed, Dec 3 2008 3:20 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,737
    • Points 67,310
    As a side note: windows management is much better on the Mac.
    Symphony 20.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Wed, Dec 3 2008 4:00 PM In reply to
    "... Doesn't quite match up and the windows go all screwy) ..."
    In the long run, it's best to have two matching displays.  I recently got 2 x HP L2245w (22") for $225 each.
    (wwld)
  • Wed, Dec 3 2008 4:47 PM In reply to
    • MisterDerp
    • Toronto
    • Posts 8
    • Points 140
    Yeah, I guess that's the best option...but my primary is a 27" behemoth and really don't want two of those on my desk!
    If I get a 24" WS for the 1920x1200 resolution it'll seem like such a waste.  Maybe a cheaper 20" 4:3 at 1600x1200 is going to be my best option.
    Thanks for the help!
