Latest post Wed, Nov 26 2008 10:54 AM by mjolnarn. 7 replies.
  • Tue, Nov 25 2008 4:40 AM
    • lenivan
    • Joined on Fri, Sep 12 2008
    • Posts 80
    • Points 1,335
    DVD creation causes jittery picture
    I've exported my timeline to Sorenson for encoding using DVD. After I encode it, some of my action sequences play jittery and not smooth as they look in MC. What can I do to fix that?
  • Tue, Nov 25 2008 7:41 AM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,665
    • Points 19,920
    Re: DVD creation causes jittery picture
    The classic solution is change the field order.
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows 7 Pro Swedish, MC7 with Symphony option, Blackmagic... [view my complete system specs]
  • Tue, Nov 25 2008 7:48 AM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Austria
    • Posts 651
    • Points 8,100
    you might encounter interlacing problems. problems might be:
    - mixed timeline (DV / non-DV footage)
    - export settings. by the way: how do you export your timeline to squeeze?
      do you use the quicktime reference files?
    - de-interlace settings in squeeze.
    - field-order settings for the MPEG2 clip
    how did you check your video? on a PC or using a stand-alone player? in which format do you produce? NTSC or PAL?
    hope we could give you some inputs - but I'm afraid that we can't help you, as long as you give us more details. if it's not an interlacing thing, could you try to post a screenshot of the problem.
    HP xw8400 - 6GB RAM | W7 64 bit | MC 5.5.2 | Adrenaline with DNxcel Sony Vaio SB1Z1 - 6GB Ram | W7 64 bit | Blackmagic Design Ultra Studio SDI [view my complete system specs]
  • Tue, Nov 25 2008 6:48 PM In reply to
    • lenivan
    • Posts 80
    • Points 1,335
    Here is my setup:
    - All the video is DV footage
    - I exported the timeline using "Send To DVD... to Squeeze" (I think that's what it's called)
    - I used quicktime reference files
    - I set deinterlacing in squeeze
    - field-order settings in MPEG2 were set to Lower Field First
    I checked my video by creatind a DVD using Encore and playing it on a stand-alone player.
    To reiterate... the action scees with lots of movie look jittery. Also, titles created in MC look jaggedy.
    What else can I check or change to improve quality?
  • Tue, Nov 25 2008 7:37 PM In reply to
    • Moses.M
    • Austria
    • Posts 651
    • Points 8,100
    it seems that you face the jittery images when there's a horizontal movement in your clip.so you have a interlace problem.
    - you could skip Squeeze and directly import your QT Ref file to Encore (as long as your version is >1.0)
    - how did you set the deinterlacing in squeeze?
    - there are several options for the quicktime reference files. (use Avid DV Codec, same as source, ....)
      try to change on after the other - not all at the same time.
  • Tue, Nov 25 2008 7:46 PM In reply to
    • lenivan
    • Posts 80
    • Points 1,335
    I will try going directly to Encore using QT Ref. I'm running Encore CS3
    I don't remember how I setup deinterlacing in squeeze as I'm not in front of that machine right now. I know for sure I used the Avid DV Codec.
    I will experiment with these settings tonight and report back.
  • Wed, Nov 26 2008 2:58 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    Hopefully you have more luck than I - I tried using QT Ref with Encore CS4 - no go. Looks like both Encore and Premiere don't like QT Ref files (no problem with AE CS4, though)...
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Nov 26 2008 10:54 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    And all of those works here with CS3 , anyone else ?
    Tomas
