I have footage that was shot 24PA, edited in a 24PA project (23.976), and transfered back onto tape via digital cut. I am trying to capture footage from that tape into a new 24P (23.976) project but can't find the correct pulldown setting. No matter what cadence I use, Advanced or Standard, Avid drops incorrect frames. I have also tried all the pulldown phase letters with both cadences with no luck. Is there anything left to try, or am I out of luck with this?
DQS
www.mpenyc.com
Thanks Dom,
I have tried every pulldown option available in the Avid and none seem to work. In the past I have had luck capturing in a 29.97 project, exporting a QTR and using After Effects to find the correct pulldown, then rendering. Problem this time is that this is a 30 minute piece and that will take quite a bit of time.
Yes. I started with the Standard cadence and tried A,B,X,C,D and none worked. Then I moved on to the Advanced cadence and did the same thing but still couldn't get the correct pulldown. This has happened to me before. I have got footage in that was 24p (not PA) and the Avid could not find the correct pull down no matter what setting I used.
I have a Panasonic AJ-SD93 DVCPRO50 deck. I think it is on the list. I love 24p, but it is always a hassle!
Yeah. I think I will just edit everything in a 29.97 project and be done with it. It will be going to DVD so I will lose true 24p but it will look the same. I do have some 29.97 that needs to be incorporated so it will save me those headaches as well. Thanks for your help Dom.
