Latest post Mon, Oct 20 2008 11:20 PM by jwrl. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Oct 19 2008 1:42 AM
    • samvideoman
    • Joined on Mon, Oct 9 2006
    • Virginia
    • Posts 87
    • Points 1,225
    running 2 nvidea cards Media composer 3.0 PC
    has anyone tested this setup, I want to monitor HD video on client monitor, With full screen preview i can use one head of my video card to run full screen and the secound will give me workspace. Id like to setup 2 workspace monitors and have a third monitor for client monitor. Could i use 2 Quadro graphics cards one would run the source/program and client monitor. the other would run a monitor for workspace, bins ect....
    Also what about those USB grphics cards that extend your display, could i use one of them to expand to a secound monitor just for bins and audio tool?
    Sam King
    Avid Media Composer Software v3 running on MacBook Pro. [view my complete system specs]
  • Sun, Oct 19 2008 2:20 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,780
    Re: running 2 nvidea cards Media composer 3.0 PC
    I'm running two nVidia cards, one quadro FX1700, on my MC3.05 system. The nVidia card drives my workstation monitor and the other Geforce card runs my HDTV monitor. I like this setup because it allows me to set the resolution of the HDTV without affecting the settings on my monitors. AVID workspace wants to span all 3 monitors, so, I have to manually drag the workspace down to two monitors..
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Sun, Oct 19 2008 11:17 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,443
    • Points 98,340
    cuervo:
    I think Bob Russo had a posting about this a while back.  He advised running display 1 on card 1 port 1, display 2 on card 2 port 1 (the cheaper card) and display 3 on card 1 port 2.  You then use display 1 for you composer and source displays, display 2 for bins and tools, and display 3 for FSP. That way you get your display quality card handling your video, and your hack card handling mainly text.
    And you would still be able to set display resolution independently with that configuration.
  • Mon, Oct 20 2008 5:01 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,415
     What about running 1 vid card (Quadro FX1700) with a Matrox "DualHead2Go" plugged into 1 port and the client monitor in the other port?  I am looking at this config:
    Port 1 - DualHead2Go splitting to my 2 CRTs giving a workspace of 2560x1024
    Port 2 - Client monitor full screen playback
    Would be a simpler option and 1 less slot on the Mobo for the PC to worry about?  My Avid rep suggested this to me?
    MC8.10 Win 7 64 with Dongle, Dual 10 core Xeon, Quadro K4000, Adaptec RAID 5-8x3TB, External TB2 4x3TB, 64G RAM, BM Intensity Pro 4K. NewBlue Titler 6... [view my complete system specs]
    Vote 1 - Dongles.
    UME an old engine, now with 4K, mags and furry dice....
  • Mon, Oct 20 2008 5:43 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,933
    • Points 70,215
    carlgmi:
    There was a post on this device too a little while ago.
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Mon, Oct 20 2008 6:06 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,415
     Thanks Luca - must have missed that thread, sounds like it will work well.  I like the idea of a single graphics card pulling system recources over the complications 2xGFX may entail.
    Vote 1 - Dongles.
  • Mon, Oct 20 2008 6:15 AM In reply to
    • jwrl
    • Posts 8,443
    • Points 98,340
    jwrl:
    Bob didn't.  Brian Williams did.
  • Mon, Oct 20 2008 11:49 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,933
    • Points 70,215
    jwrl:
    Brian Williams did
    Yes indeed, it's the post right after the one I linked.
    peace luca
  • Mon, Oct 20 2008 12:47 PM In reply to
    • jwrl
    • Posts 8,443
    • Points 98,340
    Yep.  That's the reference I meant.
  • Mon, Oct 20 2008 2:31 PM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,780
    Unfortunately, the dualhead2go is VGA input, DVI output. why would I want to leave the A-D conversion to a box like the Matrox ? Fringing and smearing has been reported with this box.
    And gamers, whose performance is critical, go with dual cards all the time. If it was too much of a drain on system resources, they wouldn't use this config.
  • Mon, Oct 20 2008 11:20 PM In reply to
    • jwrl
    • Posts 8,443
    • Points 98,340
    cuervo:
    I wouldn't go for the Matrox solution either.  Because rather than a simple A-D process, you're really looking at D-A on your display card, followed by a horizontal pixel stretch and an A-D in the Matrox box.  So it's really not surprising that you see smearing and fringing.
