Does anyone know if the Nitris DX supports 96k audio? And if so, does it down sample to 48k when out-putting to tape?
I am looking to get a DX system but want 96k support so I can use it with Pro Tools doing 96k mixes.
If you know of any white papers or documentation on the detailed specs of the DX, and can point me to them, that would be great as Ihaen't been able to find anything on the audio.
Thanks in advance.
I could be wrong but I don't see that as an option here.
BLKDOG: I could be wrong but I don't see that as an option here.
EDIT: The studio we work with in Montreal uses a Pro Tools system to record and mix.
EDIT: Ooops ! Sorry, you seem to be saying that is not an option.
The thing is don't peak too early in life.
Thanks for the response.
Per Avid the Symphony Nitris DX does support 96k. But they don't say if MC Nitris DX supports it.
Are you running MC Nitris DX or Symphony Nitris?
I have just gotten the official word that 96k/24 is definitely supported with MC Nitris DX.
Thanks BLKDOG! Did your source say anything about how Avid does the conversion of 96k/24 to 48k for output to tape?
Nope, just that it's RT out of the box.
BLKDOG: I have just gotten the official word that 96k/24 is definitely supported with MC Nitris DX.
BLKDOG:I have just gotten the official word that 96k/24 is definitely supported with MC Nitris DX
Hey Andrew......
Just had a long chat with corporate to check and here's the drill........
media Cmposer Nitris DX using v3.0 to v3.0.5, supports 96k audio. It will be located under the Audio Project Settings. The key here is.... you MUST turn off embedded SDI. If embedded SDI is on, 48k is the highest sample rate which is why you are probably not seeing it. YOu need to be on Nitris DX too.
HTH
[email protected]
Thanks alot Marianna. I dont usually look for obscure turn off's but this will immediately join my amor(y)
Cool.... report back that you are all set.
