Latest post Thu, Oct 16 2008 10:55 AM by ibayerl. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Aug 13 2008 11:02 PM
    • Lowrider
    • Posts 135
    • Points 1,855
    MC3 Crashes when trying to change QT Export settings
    I am trying to export a 1080/23.976p sequence to a Quicktime DnxHD file but when I click on compression settings, a get a Runtime Error and the program crashes.  Also when I export a QT Reference file and then try to convert it using Sorenson or any other conversion program, that program crashes when it tries to access the QT settings.
    I am running QT 7.4.5 and already uninstalled and re-installed QT.
    Anyone have this problem?
    MC5, Dell T3400, Intel Core 2 Duo E8200 / 2.66 GHz, 6GB RAM, nVidia Quadro FX570, Windows 7 [view my complete system specs]
  • Wed, Aug 13 2008 11:18 PM In reply to
    • Lowrider
    • Posts 135
    • Points 1,855
    Re: MC3 Crashes when trying to change QT Export settings
    Scratch that...updated to QT 7.5 and all seems to work at the moment.
    I am officially certifiying QT 7.5 as an Avid qualified version.  Anyone know where I send Avid a freelance bill?
  • Thu, Aug 14 2008 12:14 AM In reply to
    Lowrider:
    I've got a machine that has the same problem. I haven't found a solution yet. So I'll try installing QT 7.5 and see if that fixes it for me as well.
    Follow me at www.twitter.com/redarrowryan [view my complete system specs]
  • Thu, Aug 14 2008 3:31 PM In reply to
    Thanks, lowrider. Count me in with the same issue on a brand new Composer DX Nitris. The QT installed is also v7.4.5. Perhaps this also explains why AvidFX has been crashing everytime I try doing a QT DNxHD Export. Is there an official fix yet?
  • Mon, Aug 18 2008 3:34 PM In reply to
    • rljohnson
    • Joined on Sun, Oct 22 2006
    • United States
    • Posts 45
    • Points 525
    You may want to check your quicktime settings.  Under Quicktime Preferences go to the advanced tab and be sure your video setting is set to Safe Mode (GDI Only). There is known issues with exporting if you have DirectX turned on.
    HP XW 8600/Media Composer/7 With Symphony Option/Nitris DX/Avid VIDEO RAID SR [view my complete system specs]
    Rodney L Johnson
    Senior Producer/Editor
  • Mon, Aug 18 2008 9:40 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    Thanks for sharing this info! It is OK now over here too.
    (GDI ONLY mode didn't work fro me)
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Thu, Oct 16 2008 10:55 AM In reply to
    • ibayerl
    • Joined on Tue, Oct 23 2007
    • austria
    • Posts 22
    • Points 245
    i had the same problems when trying to change the quicktime export settings (quicktime version 7.4.5).
    setting quicktime to safe mode solved the problem for me.
    mediacomposer 3.0.5 on HP XW8200, 3.5GB RAM [view my complete system specs]
