Latest post Wed, Jul 16 2008 12:29 AM by jwrl. 2 replies.
  • Tue, Jul 15 2008 4:32 PM
    • Milco
    • Joined on Thu, Nov 29 2007
    • Rome, Italy
    • Posts 32
    • Points 440
    hdv export and m2t files
    i'm working on a project in hdv. the client would like an HD avi file while when I do an export I get an M2T file.
    anyone know what export settings I should use or if I can convert an M2T file into an avi or a mov?
    thanks a lot
  • Tue, Jul 15 2008 5:52 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,754
    • Points 62,000
    Re: hdv export and m2t files
     Unfortunately, saying you want an AVI file does not fully define the deliverable. AVI is a container to hold one or more media streams. Each stream can be in any arbitrary compressions codec (or uncompressed). As your customer which codec he/she wants and then you can use the Windows Video export option (not at my machine - don't remember what the options is called specifically) and select the codecs from there.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Jul 16 2008 12:29 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,418
    • Points 97,405
    Be aware also that Avid's AVI implementation is type I, which has a maximum file size limit of 2 GB.  It would probably be better to use a QT ref export with an external program doing the final AVI version from that.
