Latest post Fri, Jul 11 2008 1:54 PM by BarkinMadd. 2 replies.
  • Fri, Jul 11 2008 11:45 AM
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,771
    • Points 62,135
    Import of QT w/ DNxHD codec looks washed out
    As a new user, I'm just trying to get a handle on some workflow techniques. In this case, I was doing some work in AfterEffects. I decided to render using the QT movie / DNxHD codec (the source was a QT reference movie exported from MC 3.0).
    When I imported this clip back into MC, I found that it looked washed-out. The blacks weren't as black - a general drop in contrast is as best as I can describe it.
    I repeated this where the only thing I did in AE was to export the QT Ref without any changes - just put the QT ref in a composition and then rendered it back out to a new file using the DNxHD codec.
    Using the QT player I compared the QT Ref to the new file and they looked comparable (not washed out). I then imported the new file into MC and found that the import looked washed-out.
    Something about the way MC imports the QT mov w/ DNxHD codec changes the levels - is there some setting I need to adjust or am I totally off my bean?
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Jul 11 2008 12:05 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Austria
    • Posts 651
    • Points 8,100
    Re: Import of QT w/ DNxHD codec looks washed out
    Did you check your import settings? Import -> Options -> Image -> Color Levels. If you used RGB (0-255) color levels in AE you've got to select this option. If you rendered the movie within the 601/709 colorspace, take this setting.
    If your video looks washed out, try to import the QT using the 601 setting....
    Regards M.
    HP xw8400 - 6GB RAM | W7 64 bit | MC 5.5.2 | Adrenaline with DNxcel Sony Vaio SB1Z1 - 6GB Ram | W7 64 bit | Blackmagic Design Ultra Studio SDI [view my complete system specs]
  • Fri, Jul 11 2008 1:54 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,771
    • Points 62,135
    Wow - looks like I picked the wrong week to give up drinking...
    This is most unexpected. I was under the impression that the 'Image' setting was for importing images (bmp, psd, etc.) - I had no idea that it governed the interpretation of the color, etc. of video.
    Sure enough, it was set the default RGB whereas the DNxHD codec was set to 601/709 (of course).
    Switching the image setting to 601/709 had two effects. First - MC warned me that my import resolution was different (project was set to TR-145 , HDV raster) whereas I was exporting and working with square pixel 145 (1920x1080). I told MC to keep the 1920x1080 resolution - the clip imported and now looks (to my eye) exactly like the orginal source when viewed full-screen.
    Thanks so much for your help!
    Steve
