Latest post Sun, Jun 29 2008 5:36 AM by BarkinMadd. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Jun 28 2008 8:58 PM
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,771
    • Points 62,135
    Replacing media associated with a clip
    Coming from the Pinnacle Liquid workflow, I have become rather fond of being able to drag a media clip from a bin and use it to drop-replace a clip on the timeline without losing all the video effects or keyframed audio, etc. It's as if you've simply connected the clip to another media file while maintaining the rest of the metadata. The advantage of this is that you can prototype a series of effects and transitions and then simply replace the underlying media in a single operation.
    Sony Vegas has a similar but more powerful feature where you can associated several media links to a clip and cycle through them, etc.
    My question to experienced MC users is simply - can a similar workflow be accomplished with MC?
    Thanks in advanced for any guidance here,
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Jun 28 2008 9:50 PM In reply to
    Re: Replacing media associated with a clip
     Yes indeed, you can. Use the nesting function (the up and down arrow keys on the timeline tool) to step into the effect. You can then replace the footage, step back out and have all your effects keyframes and parameters intact.
  • Sat, Jun 28 2008 10:14 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,771
    • Points 62,135
     Thanks, Larry!
    Very cool - a very powerful approach as well.
    Steve
  • Sat, Jun 28 2008 10:26 PM In reply to
     You're welcome, glad to help. Also, you can save an effects template for application to other clips by dragging the effect icon from the effect editor into a bin.
  • Sun, Jun 29 2008 3:58 AM In reply to
    I believe you could also just load the clip you want to use to replace into the Source mark your In point, then park at the head of the clip to replace and choose "Replace Edit" it looks like Overwrite, but instead of a Red Arrow, it's Blue.
  • Sun, Jun 29 2008 5:36 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,771
    • Points 62,135
     Actually, that overwrites the effect as well; however, a combination of Larry's technique and yours works nicely.
    Thanks to both of you,
    Steve
