Latest post Sun, Jun 22 2008 12:34 AM by jwrl. 46 replies.
Page 3 of 4 (47 items) < Previous 1 2 3 4 Next >
  • Thu, Jun 19 2008 6:18 PM In reply to
    • fiendish
    • Posts 512
    • Points 6,275
    Re: Hows MC 3.0 Holding up!
    evansmalley - "Not to mention the dreaded interlacing blocky edges! I think you have a great point, mr. fiendish... I would so love to see MXF/AVI take over QuickTime! I see QuickTime edges on all kinds of stuff- can't believe more purists aren't up in arms!"
    Incidentally, there is a particularly ludicrious option in quicktime player that was only pointed out to me recently. In Edit, Player Preferences there is a "Use high quality video setting when available" checkbox. Make sure this is checked. DV QTs can often look as you describe if it isn't. The option also exists for individual movs in the movie properties dialog. It's a really great option that one. Idiots.
    z840 dual E5-2667v3@3.20GHz / 32GB ram / Quadro M5000 / MC 2019.12 i7-2600k Home Build / 8GB ram / MC 2018.12 xw8600 Dual Quad 3ghz - MC 5.0.4. on Win... [view my complete system specs]
  • Thu, Jun 19 2008 6:20 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Telegram!:
    For some reason, I cannot both Capture via HD-SDI and simultaneously monitor (or record) the letterboxed, SD downconverted signal coming out of the same SD-SDI cable that feeds my SD-SDI monitor perfectly when I'm playing back the 1080i timeline.
    This limitation was introduced late in the Beta process for some reason. Early beta builds could play back with the simultaneous down covert. Don't know why they changed a good thing...Brian might though.
  • Thu, Jun 19 2008 7:57 PM In reply to
    • Mark Job
    • Joined on Tue, Feb 27 2007
    • Port Hardy, B.C., Canada
    • Posts 1,620
    • Points 20,465
    BLKDOG:
    Telegram!:
     ....You mean you pay $14,000.00 US and you can't even simultaneously monitor what you're capturing ? Huh?
    EDIT: If this feature could be turned off in beta, then perhaps it could be turned back on ?
    Now Newer Avid Certified MacBook Pro version 8.3 early 2011 with Core i7 (2720 QM) Quad 2.2 GHz CPU with a 6 MB Shared L3 Cache , 16 GB of DDR 3 - 1333... [view my complete system specs]
    The thing is don't peak too early in life.
  • Thu, Jun 19 2008 8:06 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    No...no. IT shows up in the record monitor and an HD monitor, just not in an SD downconvert.
  • Thu, Jun 19 2008 9:07 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 950
    • Points 11,625
    fiendish:
    I confirmed this by mistake recently by installing OSX on my PC
    How'd you do that?
    1 MC4 Nitris DX on 12 core 2.66 mac pro 6 Gigs of Ram, 2 Symphony Nitris DX on eight core mac pro with 12 gig ram, 3 MC7 on Mac Pro, IMAC, and Macbook... [view my complete system specs]
    WWLD?
  • Thu, Jun 19 2008 9:34 PM In reply to
    • fiendish
    • Posts 512
    • Points 6,275
    long story. all part of the shadowy world of hackintoshing.
    http://forum.insanelymac.com/index.php?s=b563603b83e24736d10c35e3753c4893&
  • Thu, Jun 19 2008 10:02 PM In reply to
    evansmalley:
    let's get up a pro-Avid, anti-QuickTime vigilante rabble
    I have a pitchfork and some serious explosions in the FX files
    It is not necessary to defend QT. I don't get why people get upset that QT can't play certain files in RT. First, QT is a general purpose media player so one should expect that it has certain limitations. Second, Avid should be able to play DNxHD better. It is their own format.
    That being said, Brian Williams is right. QT just needs to be updated to take advantage of multi core systems and newer GPU features. With the announcement of Snow Leopard, I'm sure Apple is working hard to update FCP and QT's engine to take advantage of these new technologies.
    MC 2020.6, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Fri, Jun 20 2008 2:14 AM In reply to
    • Mark Job
    • Posts 1,620
    • Points 20,465
    Dom Q. Silverio:
    ...I hope we in PC Avid land will see the trickle down from the QT Apple update.Big Smile
  • Fri, Jun 20 2008 2:18 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,419
    • Points 97,410
    Don't hold your breath!
  • Fri, Jun 20 2008 2:54 AM In reply to
    • Mark Job
    • Posts 1,620
    • Points 20,465
    jwrl:
     ...Wink
  • Fri, Jun 20 2008 3:12 AM In reply to
    For this reason I love my P2 ingest It can't be beaton...
    MC 7.0 Symphony 7.0 Win 7 64bit 1 x XW 8600 quad 16gig ram 480gig SSD FX 5400 4 1tb 32 mb cache drives Pro tools 10 Avid fx Avid 3d Matrox... [view my complete system specs]
  • Fri, Jun 20 2008 10:57 AM In reply to
    • fiendish
    • Posts 512
    • Points 6,275
    Well perhaps Brian could confirm this but it seems QT is already multithreaded on the mac, in which case perhaps they don't intend to port it to PC.
  • Fri, Jun 20 2008 4:57 PM In reply to
    BLKDOG:
    Telegram!:
    Thanks for clearing that up, BLKDOG- I'm glad I have one less thing to think about.
  • Fri, Jun 20 2008 9:55 PM In reply to
    Fiendish,
    There is a good chance that parts of QT is multithreaded on the PC, too.  But it's more of an old-school style of multithreading, which worked fine in the days of 2 cores, maybe 4.
    old-school multithreading involves looking for parts of your code that you can parallelize and then run those in multiple threads.  Normally that's done on an algorythm level (for example, processing a filter which creates a blur).
    But normally, those parts are followed by parts that can't be parallelized.  This is called forking and joining.  Think about a single lane highway that suddenly becomes 8 lanes (forking) for short bits of time and then merges back down to one lane (joining).  If those lanes were cores on a CPU a good part of the time your cores are waiting around for more work to do.  Also, quite often, the join has to wait until all parts of the fork have completed.
    We've been focused on multicore and multidomain (CPU vs GPU) scalability for over 2 years now.
    Instead of parallelizing an alogorythm, we parallelize a pipeline.  Our video player is constantly do its best to process multiple frames at once.  This means that while one frame may be less busy at one of those join points, we have several other frames that are waiting to get work done.
    So back to QuickTime... what we can't do is ask QuickTime to decompress multiple frames at once.  We have to ask for each frame in a serial manner.
    I am not saying there is isn't more that we can do to improve performance.  We will certainly continue to look to improve performance where we can, it's a matter of time and prioritization.
    Brian Williams
    Senior Principal Software Engineer
    Media Products Group
    Avid Technology, Inc.
    "Be a non-conformist like me!"
  • Sat, Jun 21 2008 11:50 AM In reply to
    • fiendish
    • Posts 512
    • Points 6,275
    Thanks Brian, you've made that very clear. Does AVI work in the same way? would there be anything to gained by implementing Avid Codecs within an AVI wrapper?
