Latest post Mon, Apr 21 2008 10:06 PM by Larry Rubin. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Apr 17 2008 7:40 PM
    • steve maio
    • New Jersey
    • Posts 30
    • Points 410
    Remote collaboration workflow?
    I'm beginning to collaborate with several freelancers, spread across multiple facilities and areas.  My frustration at this point has been finding a simple solution for moving media from one system to another without shipping tapes and having a re-digitization needed.
    What I am hoping to accomplish is an easy means of moving just the multi-cam media I need from my Assistant's rig in Manhattan (she'd be in possession of the tapes), to my own in NJ, then *only* the media displayed in the final edit off to Brooklyn for Color Correction.
    While the move from the Assistant's logged, digitized, grouped, and roughed media/project file has been easy enough, where I run into a snag is passing only the portions used in the final timeline to the Color Correction system.  As a multi-cam edit, I wind up with the entire section of footage for each camera, rather than the selected clips, resulting in 5-8 times the amount of footage I really need to transfer.
    Outside of this, knocking out media files to a clean partition using consolidate seems to work ok for preparing the media files to accompany the project folder, but the process still feels... "clunky."
    Can anyone offer any methods for moving only those selected shots from a multi-cam group edit?
    In addition, can anyone direct me to a resource, application, or simply suggest methods for improving this work-flow?
    Eventually, this could prove rather moot, as technologies using CompactFlash cards , P2, and other tapeless capture become more prevalent.  For now, we're still using DV source footage at this phase, and sticking to about 5-10 min across 5-8 cameras, so the resultant media files have been rather easy to manipulate, but I can always use a more efficent means of doing this.  After all, the ultimate goal is to collaborate with anyone, anywhere, isn't it?
    Mid-2010 MacPro5,1 tower: 2x 2.66 GHz 6-Core Intel Xeon, 16GB 1333MHz DDR3 ECC, ATI Radeon HD 5770, 4x 2TB Hitachi Deskstar, Yosemite 10.10.2, Avid Media... [view my complete system specs]
  • Thu, Apr 17 2008 10:24 PM In reply to
    Re: Remote collaboration workflow?
    steve maio:
    If you consolidate your final timeline, you will create a sequence that only contains the related media used in it, plus clip handles with a length you define. You can then use the media tool to show relatives of that sequence, then reverse selection to show all non-relatives and delete those.
  • Fri, Apr 18 2008 4:25 PM In reply to
    • steve maio
    • New Jersey
    • Posts 30
    • Points 410
     Right.
    The issue however becomes the fact that we are using Groups to do a Multicam edit.  So when I use the above method, I wind up not only with the portions you see on screen, but the hidden, unused portions of the other 5-8 cameras.
    For example, lets say I have a 5 camera shoot that lasts 5 min.
    I digitize all 5 min of all 5 cameras.
    I sync and group all 5 of those clips.
    I edit the group to a timeline, starting with Cam 1 active.
    At 0:01:00:00 I cut to Cam 2.
    At 0:02:00:00 I cut to Cam 3.
    At 0:03:00:00 I cut to Cam 4.
    At 0:04:00:00 I cut to Cam 5.
    I consolidate this timeline to an empty partition in preparation for moving the media to a new system.
    What I've been winding up with here is all 5 min of footage from each camera on that partition.
    What I want is only the 1 min portion of each that the timeline used.
    So, what simple, I'll slap my forehead and kick myself for forgetting step did I skip to only wind up with 5 min of media in that partition instead of 25?
  • Fri, Apr 18 2008 4:42 PM In reply to
    steve maio:
    I'm not in front of a machine at the moment, so this might be way off, but in this particular case wouldn't you have to decompose the sequence before you consolidate it?
    good luck,
    Carl
    Media Composer 2020.12 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Fri, Apr 18 2008 4:53 PM In reply to
     Carl:
    I thought about recommending that, but unless I'm mistaken, that will take everything offline, requiring re-capture and re-import.  I didn't think he'd want to do that.
  • Fri, Apr 18 2008 5:10 PM In reply to
    Larry Rubin:
    Ah, you're right Larry.  I forgot about that.  Thanks for catching it.
    adios,
    Carl
  • Fri, Apr 18 2008 9:00 PM In reply to
    • steve maio
    • New Jersey
    • Posts 30
    • Points 410
    I may be forced to do that in the end, though it certianly isnt a streamlined workflow.
    Thanks for the suggestions so far though!
  • Sat, Apr 19 2008 10:35 PM In reply to
    If I'm not mistaken the consolidate function as a check box for group clip consolidation which I suppose should be left off.
    Alernatively you could decompose (without group clips option) and then re-link to existing media. Should have the same effect.
    Boxx Dual Xeon 3.06ghz Nvidia Quadro FX 3000 2Gig RAM Pyro 64 firewire Xpress Pro 5.7.5 Win Xp Pro sp2 Audigy Z2 Mojo [view my complete system specs]
  • Mon, Apr 21 2008 9:43 PM In reply to
    • steve maio
    • New Jersey
    • Posts 30
    • Points 410
    So I'm clear, and I'm not sitting in front of the machine at the moment, the process is:
    1) Decompose at the same resolution
    2) Relink to the existing media
    3) Consolidate to an otherwise empty drive, with "consolidate all clips in the group" DE-selected (this should create new media clips covering only the portions visible in the timeline)
    4) Move that drive to the new location (or copy its contents to BRD(s) to be overnighted, or whatever)
    Or are #s 1 and 2 unnecessary?
  • Mon, Apr 21 2008 10:06 PM In reply to
     I believe you can skip steps one and two and proceed directly to three and four.
