Latest post Thu, Apr 10 2008 4:27 PM by CR8VDO. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Apr 10 2008 3:04 PM
    • CR8VDO
    • Joined on Mon, Mar 31 2008
    • St. Louis
    • Posts 140
    • Points 1,920
    QT-Reference WHITE
    From an HDV project, I transcoded video and exported to QT-Reference in new sequence.  I can see the video just fine in Avid Media Composer, however, when I import QT-Reference into DVDit Pro HD, the video is a white only. Any ideas?  I really need to get this project done.  This is day 4.  It only took me one day to edit.
    Windows 7 Ultimate (x64) Service Pack 1 (build 7601) Install Language: English (United States) System Locale: English (United States) Installed: 12/13... [view my complete system specs]
  • Thu, Apr 10 2008 3:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: QT-Reference WHITE
    Is DVDit on the same CPU as your Media Composer software?
  • Thu, Apr 10 2008 3:26 PM In reply to
    I don't use DVDit, but I've seen the same happen when exporting MXF media from my MCA to Sorenson Squeeze and then playing it back in the Squeeze player. Although the screen turns white, my resulting mpeg-2s are perfectly OK and I can use them in Encore CS3 without any problems.
    Avid Media Composer 2020.4 HP ZBook 17 Gen3, i7-6700HQ CPU @ 2.60Ghz Win 10, 64GB RAM [view my complete system specs]
  • Thu, Apr 10 2008 3:39 PM In reply to
    • CR8VDO
    • St. Louis
    • Posts 140
    • Points 1,920
    yes, it is on same CPU.
  • Thu, Apr 10 2008 3:43 PM In reply to
    I was under the impression that you can't create a QT reference file from MXF media, something to do with the Long GOP.  I've been working on an HDV project and have been opening my MXF project bin in an SD project and transcoding to OMF media then exporting my QT reference.  This works fine and gives nice results.  I export into Sorenson Squeeze and make my MPEGs then burn with Adobe Encore.  Lovely workflow which works every time.
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Thu, Apr 10 2008 3:49 PM In reply to
    I've been working like this for a long time now but with SD media going out to Squeeze.  Sound as though we're following the same workflow.
  • Thu, Apr 10 2008 3:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    ripvanmarlowe:
    Well, I don't know about that. We export QT refs from MXF media all the time to DVD studio Pro.
  • Thu, Apr 10 2008 4:00 PM In reply to
    • CR8VDO
    • St. Louis
    • Posts 140
    • Points 1,920
    I need to keep my HD project HD for blu-ray authoring.
  • Thu, Apr 10 2008 4:19 PM In reply to
    We see the same thing when trying to export QT References or "same as source" when outputting DVCPro HD footage.
    Have you tried outputting a complete (non-reference) QT movie, or is the program simply too long?
  • Thu, Apr 10 2008 4:27 PM In reply to
    • CR8VDO
    • St. Louis
    • Posts 140
    • Points 1,920
    Problem solved - sort of.  I download the AVid codecs from the knowledge base and installed.  The video is now visible in DVDit ProHD, but is very jittery.  It also does NOT play in QT player.
