Latest post Mon, Mar 31 2008 10:49 AM by Baklap. 4 replies.
  • Sun, Mar 30 2008 1:45 PM
    • digij
    • Joined on Sun, Mar 30 2008
    • Posts 10
    • Points 170
    separating audio tracks
    I have audio on tracks [1-2] main audio    [3-4] nat sound   [ 5-6 ]  music
    I need to output my program to dv mini for another editor and they specified to make certain audio was on separate channels for them..  Upon outputting it seems that the tracks become mixed and not seperate as I have then set up in my program... How do I keep these tracks separate ??? Thanks
  • Sun, Mar 30 2008 2:15 PM In reply to
    Re: separating audio tracks
    Open the Audio Tool.  One of the buttons at the top (I'm not in front of a machine and I don't remember which one) will open up the output section, where you can choose Direct Out, which will send each track of your sequence to whatever channel you pick.
    good luck,
    Carl
    Media Composer 2020.9 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Sun, Mar 30 2008 2:54 PM In reply to
    • digij
    • Posts 10
    • Points 170
    Thanks for speedy reply, I will check this out and was hoping it would be this simple!
  • Sun, Mar 30 2008 10:20 PM In reply to
    • sasha1
    • Posts 394
    • Points 5,240
    you could make 3 duplicates of your sequence and in each one delete 4 tracks so you end up with 3 sequences, each one with 1-2 or 3-4 or 5-6 from you original, and output them one by one to tape. only takes a minute to prepare.
                         - sasha
    Avid 1: HP Z420. Quadro 4000, Motu, MC 7.02. Avid 2: Dell T3400 - Core 2 Quad 2.83 - 8GB RAM - Quadro K2000 - Matrox Mini - MC 7.02 [view my complete system specs]
  • Mon, Mar 31 2008 10:49 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,944
    • Points 82,400
    digij:
    On Mini DV on 48 Khz all you will get is 2 channels so you either need to dump 3 times or have only 2 channels. You could switch to 32 Khz and use 4 channels on DV-Cam. For anything more then 2 channel audio you will either need to export to XD-Cam, P2 or go through a Mojo SDI and embed audio 4 channel in the SDI...
    Menno
    35+ MC's - 224TB Isis - 2.2 PB Spectra T950 - Interplay - 2 Media Central's - 3 TM's - 2 STP's - 500 TB Isilon - 2 Vantage - MOG SPeedrail... [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
